Halcyon Cycyle Works Board Track Racer!
HalcyonCycleWorks
Due to some demand I am producing my frame and tank set along with a leaf spring fork. The frame/tank set unfinished is $700 the leaf spring fork is $200. Custom work is also available. I can also produce a 1" diameter handlebar which will accept a internal throttle.
Please contact Chuck
[email protected]
Halcyon Cycle Works
Chuck
I am interested in your frame / tank /leaf fork combo but with mounts for a LIFAN vertical 125CC single to keep it under my state (WI) 130CC limit for motorized bicycles and keep the cost down. I think the bottom tube will need to be modified to lower the engine case and align the drive cog to just forward of the bottom bracket. Maybe some wide cranks since the LIFAN is 14.25" at its widest? I would also love to see you build one around a LIFAN 250CC V twin!
