| | | Swap And Shop Use this forum to buy, sell or trade your motorized bicycle items. | CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. SOLD!!!!
I've got some more custom bikes coming but there's like a 3 week wait cuz I got ...  |
09-28-2008, 03:29 AM
|  | Motorized Bicycle Senior Member | | Join Date: Aug 2008 Location: The California Veterans Home
| | WARHORSE....NICE cruiser...lots of pics!!!! SOLD!!!!
I've got some more custom bikes coming but there's like a 3 week wait cuz I got alot of other bikes to build for folks and I promised them delivery so I gotta do those first. I can't even walk in my bike shop, cuz I got so many bikes, so I gotta do something. This is cooler than a Whizzer at half the price!
I've posted this bike before when I first built it, but now its got some really cool mods. I can only post four pics but you can check out more pics at motorbicycling.com.
Okay so some of the mods I've made:
I custom cut all the cables so they got a clean factory look and don't stick way out like alot of those other bikes do. I'm not doggin' those bike builders but I take alot of pride in my work, cuz each bike is a work of art to me. So I want them to be perfect every time.
I used red matching FLEX TUBE cable covers wherever required to make a clean custom look so wires aren't all over the place and it protects the wires and cables from moisture and wear caused by friction. then I zip tied them so they will stay in place and placed black zip ties at equal intervals so they look good.
I zip tied any cables that were kind of going in different directions together...again for a clean look.
I added a small black canvas tool bag to the front so you don't have to worry about carrying a backpack EVERYWHERE you go. It can be removed if you don't like it.
The rear fender is custom cut so the chain and chain guard can pass through it without cutting or rubbing it. Alot of builders take them off just cuz its kind of a pain to cut them.
I added a new rear shield-shaped reflector that looks much cooler than the stock square one.
I mounted the rear CATEYE light under the seat so you can hardly tell its there until you turn it on. It has like for our five different functions. Very clean looking, and higher up than if it were mounted on the rear fender or rack for safety.
I added some super fat rectangular rear-view mirrors each with dual orange circular reflectors.
I covered only part of the fuel line with FLEX TUBE so you can visually see your fuel flow. Very important for 2-stroke motors. A loss of fuel flow at hight RPMs will seize/destroy you motor completely. There is also an in-line fuel filter.
I reinforced the fuel tank mounting bolts with QUICKSTEEL so they are less likely to crack the tank do to vibration. BIG problem with these tanks.
I rubber insulated the fuel tank mounts. Again VERY important to prevent damage/cracks from vibration.
I installed TWO horns, each has a different sound and one is louder than the other. I mounted them on the left side so you can activate one of them with your thumb without having to remove your hand of the grip. SAFETY is paramount! Plus they look REALLY cool.
The bike has front and rear brakes, NOT coaster brakes or just one front or rear brake. In an emergency braking situation every motorcycle rider knows its the FRONT brake the saves your life. 60% of the braking occurs at the front brake. YOu should learn to use both brakes equally. Its a habit that could save your life one day.
I also added SKULL caps for the air valve covers, which looks pretty cool.
I also have red-matching SMART BUNGEES which are adjustable length and plastic hooks that won't scratch the beautiful metallic-flake red paint job.
It has a bright 2-function CATEYE front headlamp, which is not very retro, but the motor WILL produce 6 volts and I can add chrome headlamps if you want. I wanted to add dual or triple headlamps, but haven't gotten around to it.
I was also thinking about adding foot pegs high up of the front forks so you could kick back with your feet up high, and on the rear so you could haul a buddy if you wanted, although I don't recommend it, for safety reasons of course.
I'm asking 700.00 or best offer, but don't get crazy, cuz I've put alot of love into this bike.
WARHORSE builds the best bikes around and we can custom build just about any bike you want. Our bikes our built by Iraq/Afghanistan Veterans who believe we've got to start using less gas and try to use alternative fuels and transportation as much as possible so that we won't have to go to war for oil.
Motorized Bike Builder
Veterans Advocate
Sgt/USMC (fmr)
OIF 2.2 Combat Injured-Veteran
Black Death
PK-80 Powerking Limited motor, 26" single-speed Schwinn Del Mar with rear coaster brakes only (not recommended)
Top Speed: Unknown
PK-80 Powerking Limited motor, 26" 7-Speed Schwinn "Point Beach" Cruiser
Top Speed: 34
Reason: SOLD, biatches!
09-28-2008, 03:49 AM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE Here are some more pics.
Note the MAX SPEED: 30.1 on flat.
Check out the tail light.
Dual horns.
Red FLEX TUBE
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
09-28-2008, 03:53 AM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE More pics.
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
09-28-2008, 06:46 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Independence MO
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE Sarge make sure that front fender is fixed before you sell it... NICE looking bike, ooops that's cause I have one!
__________________ _________________________________________________ Well let me just quote the late-great Colonel Sanders, who said..."I'm too drunk to taste this chicken." Kings 70cc 3200+ miles. Now on a Schwinn Point Beach. |
09-29-2008, 03:09 PM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE I am going to drill a tiny hole and run a wire through as a redundant safety system.
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
10-11-2008, 12:53 AM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE So I sold her for $500.00. Extra horns and all, with some minor fender adjustments and a suspension seat. I know I could have got more, but I am eager to build a better bike and it went to a good home in Mendocino, so if you see her up there, wave hello!
I got the top speed to 32.2mph just just by porting and polishing the carb and intake manifold and polishing the exhaust manifold and opening up the exhaust a little. It did make here a little louder!
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
10-11-2008, 08:36 AM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE What type of bike are you wanting to build next?
10-11-2008, 04:40 PM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE I was thinking of a Felt or Electra, maybe. Who knows.
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
09-01-2009, 05:59 AM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: NY
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE Sarg, great looking cruiser, but if you're that much into perfection, you're cutting way too much out of the fender for the chain clearance. And if you're building bikes for others, you should never drill a hole in an aluminum frame for the motor mount. After time, that steel bolt can ream out the hole in the aluminum. You should focus more on a better mounting method and much less on bling bling and overkill with the stuff that's supposed to look "cool". Money adds up quickly on that stuff that the end buyer may not even want. You'd make more profit by eliminating some of that stuff. |
09-01-2009, 11:06 AM
| | Re: CUSTOM 80cc PK Limited Schwinn Point Beach Cruiser...NICE Oh geez. That was so last year! Thanks for your input. I built a few bikes of different styles, some I sold, some I gave away to vets, a few I kept. That PeeWee Hermanish contraption was one of my favorites though. I have never had a problem drilling the frames, although I understand why its a no-no with aluminum. The automotive bushings really help reduce vibration which I have found is the most dangerous thing about these rigs. The vibration at high rpms rattles and breaks inferior metals, which these kits are full of. I definitely don't recommend drilling frames to people thinking of mounting one of these. As a matter of fact I don;t even recommend riding one. They are dangerous and you can get hurt. That being said, I love to ride one of my bikes everyday. Its still as thrilling as ever. Maybe because they're dangerous.
Veterans Advocate
Sgt/USMC (fmr)
Black Death
Top Speed: Unknown
Top Speed: 34
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:44 PM. | | | Sponsors
