| | Clutch throw out pin Discussion at Motorized Bicycle Engine Kit Forum in the Swap Shop forum. Anyone have the clutch throw out rod thing. The round rod with the flat side. Not the entire arm, just ...  |
04-25-2008, 12:22 AM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Daytona Beach
| | Clutch throw out pin Anyone have the clutch throw out rod thing. The round rod with the flat side. Not the entire arm, just the part that pushes in the clutch sprocket thing. |
04-25-2008, 01:01 AM
| | Re: Clutch throw out pin Most likely gonna need to try one of the dealers. Maybe the one who sold you the engine. |
04-25-2008, 07:40 AM
| | Re: Clutch throw out pin If you can't find one see if one of the members won't measure it for you. It's nothing but a chunk of steel. I would do it but I don't have a micrometer. You do still have the ball bearing that is behind it don't you? |
04-25-2008, 09:35 AM
| | Re: Clutch throw out pin That is not the part I need. I am talking about the round rod that the clutch arm connects to. I did not know there was a ball bearing behind the metal rod. |
04-25-2008, 11:24 AM
| | Re: Clutch throw out pin The one I was thinking of is more or less an extension rod. It is about an inch long and comes right out of the clutch assembly. there is no retainer of any kind on it. Between that rod which allows the clutch lever to push the clutch mechanism and engage there is a free ball bearing. I am always warned to be careful not to lose it. So maybe you add send a picture of the part you need. |
04-25-2008, 12:24 PM
|  | Master Motorized Bicycle Builder | | Join Date: Feb 2008 Location: Metro Washington, DC
| | Re: Clutch throw out pin If you PM me with your address, I'll send you a new one. I have a spare one from a bottom end rebuild. I'll send it to you with the arm still attached.
__________________ Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
04-25-2008, 07:02 PM
| | Re: Clutch throw out pin YOU are the man!
04-26-2008, 12:58 PM
| | Re: Clutch throw out pin Wow, thanks for all the help, but I found it on the side of the road, lucky! I also found someones motor mount for a Ford V8, and I thought I had problems. |
04-26-2008, 01:04 PM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | Re: Clutch throw out pin Quote:
Originally Posted by sisdavid Wow, thanks for all the help, but I found it on the side of the road, lucky! I also found someones motor mount for a Ford V8, and I thought I had problems. | That's hilarious!
If you find my two set screws, give me a shout!  |
04-26-2008, 05:14 PM
| | Re: Clutch throw out pin Heck I lost a kick stand somewhere between my house and the marina. If anyone finds it there is a thank you but no reward... | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:49 PM. |
