Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap Shop
Clutch throw out pin
Discussion at Motorized Bicycle Engine Kit Forum in the Swap Shop forum. Anyone have the clutch throw out rod thing. The round rod with the flat side. Not the entire arm, just ...
Old 04-25-2008, 12:22 AM
Default Clutch throw out pin
Anyone have the clutch throw out rod thing. The round rod with the flat side. Not the entire arm, just the part that pushes in the clutch sprocket thing.
Old 04-25-2008, 01:01 AM
deacon's Avatar
Default Re: Clutch throw out pin
Most likely gonna need to try one of the dealers. Maybe the one who sold you the engine.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
Old 04-25-2008, 07:40 AM
deacon's Avatar
If you can't find one see if one of the members won't measure it for you. It's nothing but a chunk of steel. I would do it but I don't have a micrometer. You do still have the ball bearing that is behind it don't you?
Old 04-25-2008, 09:35 AM
That is not the part I need. I am talking about the round rod that the clutch arm connects to. I did not know there was a ball bearing behind the metal rod.
Old 04-25-2008, 11:24 AM
deacon's Avatar
The one I was thinking of is more or less an extension rod. It is about an inch long and comes right out of the clutch assembly. there is no retainer of any kind on it. Between that rod which allows the clutch lever to push the clutch mechanism and engage there is a free ball bearing. I am always warned to be careful not to lose it. So maybe you add send a picture of the part you need.
Old 04-25-2008, 12:24 PM
Autocycler's Avatar
If you PM me with your address, I'll send you a new one. I have a spare one from a bottom end rebuild. I'll send it to you with the arm still attached.
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Old 04-25-2008, 07:02 PM
Bikeguy Joe's Avatar
YOU are the man!
Old 04-26-2008, 12:58 PM
Wow, thanks for all the help, but I found it on the side of the road, lucky! I also found someones motor mount for a Ford V8, and I thought I had problems.
  #9 (permalink)
Old 04-26-2008, 01:04 PM
Pablo's Avatar
Amsoil Dealer
That's hilarious!
If you find my two set screws, give me a shout!
http://oilslubesfilters.com/
  #10 (permalink)
Old 04-26-2008, 05:14 PM
deacon's Avatar
Heck I lost a kick stand somewhere between my house and the marina. If anyone finds it there is a thank you but no reward...
