Re: Bearing in rear wheel Yes you can put the bearings in loose. It will take roughly twice as many balls as what are in the cage, dip each ball in a good quality high temp grease and it will help hold them in place until you are ready to reassemble the wheel. From what I can see it looks like your wheel was too tight and you basicly burned up the set that you took out, I've done this. If you don't wan't to go with the loose balls you should be able to get a new set from your LBS for a couple of bucks, make sure to get the right size, I would reccomend taking what you have left or the wheel with you...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
