Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap And Shop
Bearing in rear wheel
Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. Yes you can put the bearings in loose. It will take roughly twice as many balls as what are in ...
  #11 (permalink)
Old 06-08-2008, 11:10 PM
nogoodnic's Avatar
Default Re: Bearing in rear wheel
Yes you can put the bearings in loose. It will take roughly twice as many balls as what are in the cage, dip each ball in a good quality high temp grease and it will help hold them in place until you are ready to reassemble the wheel. From what I can see it looks like your wheel was too tight and you basicly burned up the set that you took out, I've done this. If you don't wan't to go with the loose balls you should be able to get a new set from your LBS for a couple of bucks, make sure to get the right size, I would reccomend taking what you have left or the wheel with you...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
  #12 (permalink)
Old 06-09-2008, 12:56 PM
spad4me's Avatar
I must be lazy. I just unscrew the cone and add more grease on top of the bearings.
  #13 (permalink)
Old 06-09-2008, 05:47 PM
Motorized Bicycle Apprentice
I have overhauled probably hundreds of coaster brake hubs in my days; here are a few tips on overhauling/adjusting them.
Loose balls are very difficult in a coaster brake hub as the cup that the bearings sit in is very different from a typical hub, headset or bottom bracket. I highly recommend spending the whole dollar and replacing the retainer as well. Pack the bearing with grease until the grease is coming out the other side, then add more after the bearing is sitting in the cup. Don't put the bearing in backwards; that'll wreck the new bearing in a hurry.
Always do the hub adjustment from the drive side (with the cog). Leave the side with the brake arm alone (locknut tight against the brake arm). Even during the overhaul, there is no reason to loosen that locknut.
As with any hub adjustment, tighten the cone/locknut on the drive side only enough to take the play out of the axle. It's trial and error; 1/8 turn can be the difference between too loose and too tight.
You can almost never have too much grease in a coaster brake hub, kind of like you almost can't overcook a braut. The photo above looks to me like the hub was dirty and not enough grease.
Good Luck, Steve
Similar Threads
Rear wheel, spokes and bearings toytime Motorized Bicycle General Discussion 28 06-12-2008 10:59 PM
Motorized Bicycle Rear Wheel RedB66 Motorized Bicycle General Discussion 1 04-03-2008 09:16 PM
Repacking/Overhaul Those Wheel Bearing... Autocycler Pre-Motorized Bicycle Information. 3 03-14-2008 04:07 PM
Repacking/Overhaul Those bicycle Wheel Bearing... Autocycler Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 2 03-14-2008 03:20 PM
Wristpin Bearing Upgrade? Bikeguy Joe Bicycle Engine Kits 26 02-28-2008 05:02 PM
