Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap And Shop
15 % Off Harbor Freight 3 day Sale
Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. Hi Y'all Just got this in. I always check my email before going to HF. I get coupons from ...
Old 11-21-2008, 02:01 PM
xPosTech's Avatar
The Old Master Motorized Bicycle Builder
Default 15 % Off Harbor Freight 3 day Sale
Hi Y'all
Just got this in. I always check my email before going to HF. I get coupons from them periodically. Since I was gonna pick up their 2.5 HP 4 cycle today, lo and behold this was in my in basket.
Right click it, use save image as and then print it out. That's for Firefox. I'm sure IE is similar. If you can't do that, here's a link to it. Here are some more coupons.
The 2.5 HP 4 cycle is on sale in their mail out for $89.99. This coupon will get it for you at $76.49. It usually sells for about $100 so about a $24 savings. This sale is only today, Saturday and Sunday so hurry if you want this engine.
You can use the coupon for any single item, so use it for the most expensive.
Have fun.
Ted
I wasn't born in Texas but I got
back here as soon as I could.
Help support the forum.
Donate today.
Old 11-21-2008, 02:06 PM
xPosTech's Avatar
Default Re: 15 % Off Harbor Freight 3 day Sale
Another thing. When you fill it out, use a good addy. They don't pass around your addy (as far as I know) and you will start to get coupons in your inbasket. You can also go to the website and subscribe to their coupons. Do it. It's worth it.
Also if your see an item online at a lower price than the store, print the page with the price and barcode. They will sell it at that price if you're nice.
Enjoy.
Ted
Donate today.
Old 11-21-2008, 02:08 PM
fairracing31's Avatar
I've seen the sale and been looking at the motor!! Just have not had the time to get down there.
Link to motor..
Harbor Freight Tools - Quality Tools at the Lowest Prices
Old 11-21-2008, 02:55 PM
jasonh's Avatar
Cool lookin motor. I'm curious if it would work for a bike though...the specs say 3600rpm...does that mean it just sits at 3600, that's the max, or that's what the power is rated at?
Old 11-21-2008, 03:00 PM
3600 max rpms....it's not a fast motor and if you noticed it says "generator". It's an industrial type motor.
But for the price and some smart gearing it would work for me.
Old 11-21-2008, 04:53 PM
Dan's Avatar
Dan Dan is offline
Thanks Ted! Coupons are a good thing
Really like this motor and you can't beat the price.3600 rpm is actually a good thing. A GX50 maxs out at 7200 and needs lots of reduction.
The engine is really perfect for a MB but is wide. I am going to use one for a pusher engine. I wrote to them a wile back;
Karin Moon
Customer Service.
Tracking no. T40605
SKU: 97964 - 2.5HP HOR.OHV GAS ENGINE
DESCRIPTION:
Customer would like the dimensions of this item, particularly
interested in it's width.
ANSWER:
These dimensions should be entered into op. 6.
Overall: 12" L x 11" W x 11-1/2" H (Width includes
the shaft)
Shaft Size: 2-1/4" extension length x 5/8" diameter x
3/16" keyway
Base Mount Pattern: 2-1/2" W x 4-1/8" L (4) M8 x 1.25 threaded holes
Shaft Mount Pattern: (4) M8 x 1.25 threaded holes equally spaced on a
3.61" diameter circle
Originally Posted by NEAT TIMES View Post
looking In The Sky, May See Dan Flying By!! Ha Ha Ron
I want 2 ride my bicycle
Old 11-21-2008, 08:40 PM
xPosTech's Avatar
Yeah Dan it seems wide. That's with the pull start and fan shroud, muffler, gas tank and air cleaner. It's an OHV so I think it's a Honda clone. I can't tell by the pic online but I'm sure (I looked at it IRL several months ago) it has the drain screw on the carb bowl.
That 3600 RPM rating is governed speed. The throttle on a governed engine does not directly move the throttle plate in the carb. It usually varies spring pressure on the governor, with a reserve higher RPM capability to overcome differences in load. We can tap that reserve capability.
Properly set up, you can have a standard throttle grip and Cruise Control! There is a caveat, though. Hitting the brakes will not release "cruise". We'll have to make sure the kill switch (that works) is close to our right thumb.
With a set of the old friction shifters on the top tube, we can have auxiliary throttle (Cruise Control) and choke levers. This will be almost true cruise control. Head up a hill and throttle opens up to keep speed constant. Thing is, heading downhill it will stay at 3600. It will back off the throttle but won't close it completely.
These engines are designed for generators. They will run day in day out. Cast iron cylinder sleeve. Low oil shutdown. Ball bearing shaft. For less than $80 dollars you can't beat it.
Ted
Donate today.
Old 11-21-2008, 08:44 PM
xPosTech's Avatar
Sometimes you say well. Sometimes you say well shoot.
No 2.5 HP engines at the Beaumont HF. "I have two on the truck that will be here Monday" says Josh, one of the managers.
"But my coupon expires Sunday night" says I.
"No problem" says Josh. "I'll write you a raincheck. You can use your coupon when it gets here."
"Can I buy you some coffee? " says I.
They know me by sight at HF. Stores that take care of their customers should be cultivated.
Ted
Donate today.
  #9 (permalink)
Pablo's Avatar
I just bought some China stuff from HF, finally got a grinder pedestal!
  #10 (permalink)
Old 11-22-2008, 10:34 AM
Angry Old Fart
I wanna make sure I understand this. The carb is set up to purr along at 3600 with minor increases under a sensed load. An earlier post mentioned that it can be throttled like a regular engine. Is that possible on these carb/engine set ups?
Like does the spark timing advance at the touch of the throttle? or does it plod its way to 3600 then tops out?
This looks like a mega deal of an engine though. At that price, heck I can change out the advance and carb anyway...
The only normal people are the ones you don't know very well.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f23/15-off-harbor-freight-3-day-4716.html
Posted By For Type Date
15 % Off Harbor Freight 3 day Sale - Motorized Bicycle Engine Kit … | damagefreight.com This thread Pingback 11-22-2008 01:13 PM
