Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Welcome Forum > Welcome to the World of Motorized Bicycles
Welcome to the World of Motorized Bicycles Learn all about your motorized bicycle engine kit. how to mount the kit, and information for modifiying your bicycle engine kit
Yong Xing
Discussion at Motorized Bicycle Engine Kit Forum in the Welcome to the World of Motorized Bicycles forum. Dud this sight is awsome just read a little. The spokes will break if you put the rubber peices in ...
  #11 (permalink)
Old 08-27-2008, 03:38 AM
goat herder's Avatar
Default Re: Yong Xing
Dud this sight is awsome just read a little. The spokes will break if you put the rubber peices in the wrong place . Trust us! The rubber peices only go as like this , they protect your spokes. Put one between your sprocket and the spokes, then one the other side the inside of the hub other side of spokes your last rubber peice. Then the two or three metal peices, depends on weather your have the 6 millimeter or 8 stud bolt on set up. Finaly studes and washers, and nuts. Bottom line the rubber protects the the spokes.
  #12 (permalink)
Old 08-27-2008, 06:37 AM
Motorized Bicycle Apprentice
Originally Posted by NEAT TIMES View Post
Anthony, If You Have The Kit That I Beleive You Have, There Is Only I Gear (speed) There Is No Neutral. Only Clutch Engaged Or Disengaged. The Little Arm Above The Motor Sprocket Is The Clutch Release Arm. The Clutch Is On The Other Side Of Motor, Under The Cover. A Rod Runs Thru A Hollow Shaft To The Other Side. Take Cover Of Booth Sides And Study It. You Will Have To Learn How To Adjust Clutch. Be Careful So You Don`t Break Clutch Arm. Its Basic Clutch, Once You Understand It. When You Take Cover Off Rite Side, You Will See Small Gear On Motor Crankshaft The Drives The Big Gear On Clutch Housing. The Clutch Drives The Chain Gear. Study It And Read The Pertinate Posts. It Will All Fall Into Place For You. Take Your Time And Enjoy Your Build. They Are Great Little Motors, They Love Attention, And You Can Not Holler At Them. Ha Ha. Ron
Thanks.
I read Norman's witty, yet helpful post on the clutch. One thing he points out is the adjustment of the flower nut. It seems that no matter what I turn (this flower thing included) the whole engine is turning over.
There are three levers. The biggest is the brake lever. The next biggest is the one that that has a dial that goes from one to three and the smallest goes back from three to one. All levers are functioning, though now I'm wondering why they're numbered. Is it perhaps the case that when it's on #1 it won't be strong enough to move the chain?
This is what I'm up against:-
'At the ends of the handle of the clutch, please ensure keep a certain free space, generally 2-3 mm. Only proper space able to ensure the timely decoupling of the clutch and free of slipery. In the course of adjustment, loosen the handle of the clutch, turn the hollow-center screws, turn outside for decrease of space, turn inside for increase of space. After adjustment, tighten the nuts and avoid loose. If slipery in case of proper space, dimantle the cover of the clutch to check if the cover sleeve of the clutch is loose, and tighten if necessary.'
And that's their 'definitive' clutch bit.
This site http://www.livefastmotors.com/pdf/two_cycle.pdf that jasonh posted shows what appears to be the exact same engine, but without a brake type lever for disengaging, just the two click levers as previously described, though on the throttle handle there is a kill switch.
Any further thoughts would be much appreciated.
Thanks also goat herder. Now I have to choose between your advice and theirs, which reads:-
'Install the assembly of gear disc at the rear wheel of the bicycle, cover the outside tightening rubber at the rear axle, then cover the assembly of gear disc, its concave side closely attached to rubber. At the other side of the steel wires of the rear axle of the bicycle, install the inside tightening rubber, press the outside tightening rubber with small and large tightening plates. Install and tighten the assembly of gear disc at the rear wheel. In the course of tightening, ensure the radial and axial deflection between the gear disc and the rear axle less than 1 mm. Don't tighten excessively, tighten only for alignment of the assembly.'
Hmm. Difficult choice.
Ant
  #13 (permalink)
Old 08-27-2008, 07:15 AM
Bikeguy Joe's Avatar
MODERATOR
As to your problem, sometimes, even if the clutch is disengaged, the sprocket can be very hard to turn when new.
  #14 (permalink)
Old 08-27-2008, 07:17 AM
MODERATOR
Don't even bother with "instruction" that comes from China...you will be lost in the wilderness for days.
  #15 (permalink)
Old 08-28-2008, 10:45 PM
bicycleengine's Avatar
I know a good website from Austrilia.
that is www.zbox.au,
you can go there and find the fitting instruction
  #16 (permalink)
Old 08-28-2008, 11:23 PM
Saddletramp1200's Avatar
Another way is to use a spark plug wrench after you take the spark plug out and rotate the counter sprocket. Some kits come with the wrench.
No matter where you go, or what you do, there Ya' are!
  #17 (permalink)
Old 09-24-2008, 08:06 AM
Anthony, remove the spark plug, remove the clutch actuator (3 screws) and use a 19mm socket wrench to rotate the front sprocket, start the chain on the bottom of the sprocket. The instructions show both rubber gaskets on the same side of the spokes, I think you will find that most on here suggest that this is incorrect, "sandwich" the spokes between the rubber gaskets, and IF you can CUT the gaskets with a SCISSOR get different ones.... you will need a stout sharp knife to cut only one gasket for the "inside of the spokes"..... good luck
  #18 (permalink)
Old 09-24-2008, 08:58 AM
the correct link is MOTORISED BICYCLE ENGINE KIT ZBOX BIKE MOTOR AUSTRALIA 48cc MOPED - AUD$235
  #19 (permalink)
Old 09-27-2008, 05:54 PM
who sells the best bicycle motors?
  #20 (permalink)
Old 09-27-2008, 07:06 PM
Oh amealnet, that is a tough question. I use the motors thatsdax supplys. They have fantastic customer support and a very good motor I think.
Advertisers
