| Sponsors
| | | | | Welcome to the World of Motorized Bicycles Learn all about your motorized bicycle engine kit. how to mount the kit, and information for modifiying your bicycle engine kit | Lady In Need of Advice Discussion at Motorized Bicycle Engine Kit Forum in the Welcome to the World of Motorized Bicycles forum. Welcome, I agree for the most part w/ walks,tramp & joe. But "necessity is the mother of invention&...  | |
10-12-2008, 01:32 PM
|  | Master Motorized Bicycle Builder | | Join Date: Sep 2008 Location: Seattle
| | Re: Lady In Need of Advice Welcome, I agree for the most part w/ walks,tramp & joe. But "necessity is the mother of invention" so let him make some mistakes and possibly overcome some inherant problem in a clever way. And VOILA! you've invented Thneeds or doohickies or widgets!
Failure Can Be Fun!
For example: I ate a chain yesterday when it derailed off my rear sprocket. I wasn't thrilled but I hated the stock drive from go. So heres an opportunity to find or MAKE some sort of thingamajiggi that not only fixes it but makes it better.
Failing Can Be Fun, and sometimes I gotta get mine!
Reason: 'nit pickin'
10-13-2008, 12:00 AM
| | Senior Motorized Bicycle Builder | | Join Date: Sep 2008
| | Re: Lady In Need of Advice I suppose you are speaking of the 2 stroke 50 or 70cc Gru Bee or similar motor. I think the worst problem is vibration loosening nuts. I would recommend Loc Titeing everything you don't want to fall off. Also it is very important to observe the heavy oil mix for the break in period and not extending the motor during that period as the oil-rich mix means a gas-lean mix and can cook the engine wide open. Also, every run for awhile should be followed with re-torquing the head bolts after cool. I have found starvation at high speeds due to the restrictive fuel tap. I intend to install an inline filter and eliminate the fine screen in the tank. That's about all I know about these crudely made little things. They require care due to the metallurgy. I have yet to decide how to ensure adequate lubrication for the primary drive gears, which are quite noisy. At this point I have packed it with bearing grease and inserted a piece of currogated cardboard in as someone suggested to deaden the gawdawful embarrassing clatter. Helps a little. Next I will see if the case can contain a bit of differential lube without oiling down the clutch. If so, a filler and level plug will follow. I think quantity is the rule. It is a high-pressure lube containing sulfur. It is rough on brass or bronze. Good luck. You CAN do it.
Keith (trackfodder) Williams
10-13-2008, 07:29 AM
| | Re: Lady In Need of Advice When I retired my son in law took over my business... not mechanics.... he and my daughter run it now.... the business has kept the marriage together a few times when things got rough... they need each other to run it...
It sure kept me and the wife together when person things got hairy,,, |
10-13-2008, 08:03 AM
|  | Motorized Bicycle Apprentice | | Join Date: Sep 2008 Location: Wisconsin
| | Re: Lady In Need of Advice Hello Frinds,
Thank you all so much for your great advice. It is so greatly, greatly appreciated. Sad new, my boyfriend (Dow) passed away Saturday. As for myself (Ty) at this time I am not sure if I am going to keep going with our plans or not. It does bring great comfort knowing that Dow loved is motor bike very much.
Again, thank you all so much and I will be back to visit soon. All prayers are welcome.
Ty |
10-13-2008, 08:20 AM
|  | Motorized Bicycle Builder | | Join Date: Aug 2008 Location: Deerfield, NH
| | Re: Lady In Need of Advice I am so sorry to hear that. Condolences and prayers sent your way. |
10-13-2008, 02:45 PM
| | Re: Lady In Need of Advice Quote:
Ty | I am so sorry to hear about Dow...my prayers are with you Ty
David |
10-13-2008, 08:49 PM
| | Motorized Bicycle Apprentice | | Join Date: Oct 2008 Location: Philippines
| | Re: Lady In Need of Advice I am sorry to hear about that...... My prayers are also with you TY
_________
jay |
11-28-2008, 03:10 AM
| | Motorized Bicycle Builder | | Join Date: Jul 2008
| | Re: Lady In Need of Advice TY
I have the same problem but I like working on my bike and have built others to sell. If he will not read and learn when he gets mad and walks away just pick up the tools and start working or just work on your bike (what made my guy mad was my bike was faster than his because of a little tweeking I did  )
These engins are tough and will last a long time with basic matanance and making sure the gas and oil is mixed right and tighten the nuts that lossen up befor you go on your ride.
If you are making the bikes make sure to use lock tight (in a pinch I used clear finger nail polish) and the tires are in line that little wobble at 35 is not good.
PS print up the articals you like and make a bike book it will help.
old lady biker
Cookie |
11-28-2008, 01:05 PM
| | Re: Lady In Need of Advice TY I am sorry to hear about your boyfriend me prayers are with you
Cookie |
11-28-2008, 01:36 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: Lady In Need of Advice Ty, I know. It comes back tho. You have over 1400 friends right now  We won't give up on you. It gets better. Godspeed Tramp
No matter where you go, or what you do, there Ya' are! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:06 AM. | | |
