| | | Suggestions This is the members forum. Help to make the motor bicycle engine kit forum better with your suggestions | STP Octane Booster Discussion at Motorized Bicycle Engine Kit Forum in the Suggestions forum. i found out that if when you go to mix your fuel, if you put in about 4 ounces of ...  |
08-29-2008, 12:53 AM
|  | Dealer | | Join Date: Aug 2008 Location: Monrovia,CA
| | STP Octane Booster i found out that if when you go to mix your fuel, if you put in about 4 ounces of STP Octane Booster (99cents store stuff) it will make a considerable difference in mid-to high RPM's.
Vertigo Motors, 50CC complete bicycles starting at $300, 66CC starting at $315
Contact at Vertigomotors@gmail.com ..................live long,live fast,ride to cruise,not to speed,and you will enjoy your china girl to its fullest! |
08-29-2008, 07:09 AM
| | Re: STP Octane Booster That would be the case if you are running too rich...the octane booster "thins out" the fuel for the fuel/oil mix, thereby making a rich(er) engine lean out closer to peak performance.
Higher octane is pointless to the china in frame engine since the compression is already very low.
08-29-2008, 07:05 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: STP Octane Booster But what does it do to a chainsaw engine or a weed whacker engine lol |
08-29-2008, 07:11 PM
| | Re: STP Octane Booster Not much.
Octane booster make higher octane. Higher octane make the mix burn slower and is handy with high compression engines so they don't pre-detonate.
08-29-2008, 11:42 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Albuquerque
| | Re: STP Octane Booster  Another thing about octain boosters is they can clean the carbon out thus improving the availible oxygen in a given motors combustion chamber, like fuel induction cleaning. Not much experimenting can be done on these chinas, danger will robenson. |
08-30-2008, 02:53 PM
| | Re: STP Octane Booster I was joking lol I figure that there is nothing that can be done past cleaning the carb now and then... |
09-03-2008, 04:01 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: STP Octane Booster My Girl Friend Wants Me To Take Octane Booster, And I Know Why !!
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER |
09-03-2008, 05:11 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: STP Octane Booster Probably better off yanking off the head and manually cleaning for carbon removal.
I'm curious how well seafoam works on these motors as far as a good cleaning. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:12 PM. | | | Sponsors
