| | | Suggestions This is the members forum. Help to make the motor bicycle engine kit forum better with your suggestions | Engine performance vs. engine performance Discussion at Motorized Bicycle Engine Kit Forum in the Suggestions forum. In my field as an automotive technician (mechanic) we have a term for engine performance problems.. driveability, (which happens to ...  |
05-29-2008, 12:26 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Santa Cruiz, CA
| | Engine performance vs. engine performance In my field as an automotive technician (mechanic) we have a term for engine performance problems.. driveability, (which happens to be my line of work, along with electronics, but I digress) which is quite different from engine performance in terms of increasing performance, rather than a lack of normal performance. It would be wonderfully helpful to separate the two with distinct sections, so the posts about sputtering under load won't be alongside to the bottle debate. |
05-29-2008, 05:40 PM
| | Re: Engine performance vs. engine performance Yes, performance doesn't always mean to "hop up" or "modify for racing purposes".
06-14-2008, 10:56 PM
| | Re: Engine performance vs. engine performance Okay, how about a "troubleshooting" section separate from performance upgrade section?
Please? |
06-15-2008, 12:05 AM
| | Motorized Bicycle Newbie | | Join Date: May 2008
| | Re: Engine performance vs. engine performance I thing a troubleshooting section would be great, I have been trying for two weeks to get my 99 whizzer to run properly, no luck yet, its better but not right,it idles well, runs ok at low speed but when I try and accelerate it bogs down never seen 25mph, it is running very rich and I need a 74, and 72 main jet, if you have one I would like to buy itThanks Paul navion@q.com
trouble shooting forum has been added in the bicycle motor main forum |
06-15-2008, 05:58 AM
|  | Motorized Bicycle Member | | Join Date: Jun 2008
| | Re: Engine performance vs. engine performance Can you dissasemble the muffler on that model to check if its restricted?
If your not sure, ask a friend first!   |
06-15-2008, 11:20 PM
| | Re: Engine performance vs. engine performance Hi and thanks for your reply, the bike only has 10 miles, and I did check the muffler . |
06-17-2008, 04:44 AM
| | Re: Engine performance vs. engine performance I dont know if this helps, but I have about same miles. My carb began to fall apart. the fuel inlet loostened up and poored half my tank on the ground. I suggest retightening everything on these kits. You never know what you will miss. As far as actual changes in the powerband. Its all about the pipe. Short pipe, good bottom end power & less top end. Long pipe, less bottom end power but more top end speed.
If your not sure, ask a friend first!   | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:50 PM. | | | Sponsors
