| Sponsors
| | | | | Travels and Adventures Use this forum to tell us about your motorized bicycle travels around the neighborhood or around the world | Riding in the hood. Discussion at Motorized Bicycle Engine Kit Forum in the Travels and Adventures forum. I got my son in law up on the bike tonight. He was suitably impressed. With a little luck I'...  | |
03-02-2008, 04:13 PM
| | Re: Riding in the hood. I got my son in law up on the bike tonight. He was suitably impressed. With a little luck I'll have him on his own bike and someone to ride with. I'd like to get a few of us so I can find someone to joy ride with. |
03-02-2008, 09:40 PM
| | Re: Riding in the hood. Deacon
Thats great you are just the man to show him the ropes as well you now have a good working knowledge of the bike and how to make it work. How thick of a base gasket did yo go back with when your did your tear down?
Norm |
03-03-2008, 06:06 AM
| | Re: Riding in the hood. I reused everything from the original build. I was lucky nothing had to be replaced except the rings. I just slathered all the gaskets with bearing grease. |
03-03-2008, 08:49 AM
| | Re: Riding in the hood. I just realized something this morning.. it is ten am and the temperature is over 50. I bought and built my bike so I could run errands, and now I don't have any errands and I still want to ride. I am trying my best to think of an excuse to ride. I know I don't need one but still lol.
I think i need to test pulling a trailer with the bike, yeah that's the ticket test the trailer pull.
03-03-2008, 04:37 PM
| | Re: Riding in the hood. every time I have a bad day with the bike I still learn something. Yesterday my son in law rode the bike and the brake lever broke loose and got stick against the side of the bike. I freed it today and then had to kick the brakes a few times because they got locked. Had other strange noises off and on, so I decided to pull the wheel and see it I could loosen the brakes.
Then I found it. One of my bolts that holds the rear sprocket on got sheered. No telling what other damage it did but I replaced the bolt with a quarter inch one inch long hex head bolt and it fits perfectly. Not only that but the bent coaster brake clears the hexhead just fine. At least it did on the test ride. |
03-03-2008, 11:25 PM
|  | Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Davis, California
| | Re: Riding in the hood. Phew, tarmac embrace avoided! For another day...
I'll have to remember to keep an eye on my sprocket bolts from now on.
-Herman "Do not take life too seriously. You will never get out of it alive." -Elbert Hubbard
03-04-2008, 01:28 AM
| | Re: Riding in the hood. I have no idea what really happened. It's also possible the nut fell off and it worked itself our far enough to be popped off. I found the head of the nut in my drive way but I never did find the nut. At least I think that's what I found. |
03-04-2008, 07:40 AM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Riding in the hood. Are you saying your brake arm for the coaster brake came loose?
I made a strap out of heavy furnace strapping metal (technical term there) and used a heavier nut and bolt.
03-04-2008, 09:10 AM
| | Re: Riding in the hood. yes it either broke loose or the bolt came out not sure which. When son in law got back the brake arm was pointing straight up in the air an in the wrong direction. I made a heavy duty strap from a pipe clamp and found a heavy bolt for it. I'm going to keep an eye on it from now on.
I'm learning as I go along. Next time I build one i'll have all this crap figured out. then I can have new crap go wrong lol. |
03-04-2008, 11:44 AM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: Riding in the hood. Deacon, you will want to check your wheel to make sure its not loose or too tight. I sheared my brake bolt one time while a car was trying to check me out comming toward me in my lane  , I locked up the rear wheel, snapped the bolt, missed the car, and continued to ride for a short ways. All of a sudden my rear hub locked up and my bike started ridding like a fixie with my pedals spinning at speed. My coaster brake had spun four full turns tight, clamping the bearings down so the wheel froze up...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:05 PM. | | |
