Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Pictures and Videos
Pictures and Videos Use this forum to share pictures and videos of your motor bicycle.
SchwinnWacker first build, more to come
Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. I could wait no longer and I happened upon a free weed wacker on craigslist so... I decided to make ...
Old 08-10-2008, 06:42 PM
Talking SchwinnWacker first build, more to come
I could wait no longer and I happened upon a free weed wacker on craigslist so... I decided to make a friction drive.
The main goal of this build- cheap, build it out of as much stuff I had around the garage as possible. I've sunk very little cash into this but see how I could.
The engine had very little wrong with it, just needed a new gas line, fixed that quick and easy.
I had tried to make the mounts out of the steel from a broken box fan... Which I think would work if my bike were bigger and I tried a different sort of mount. Anyway. I had plenty of 1/4 all-thread the tubing from the weed wacker and some 1/8th aluminum all left over from other projects.
I bent and shaped a mounting bracket from the aluminum and used the all thread inside the wacker tube to support the all thread and maintain a little stiffness. all in all it works pretty well. It can't haul my fat butt from a standstill but if I get it up to speed it will accelerate, and keep me going at a good clip. I put the speedo on it today and made a mount for a video camera with the last of the wacker tube.
I'll be looking into getting some slick tires for it and a registration.
pics:
It's mounted on a 1996 schwinn S95.6 a sweet ride I've spent hundreds of hours on. I call it the ScwinnWacker now.. I'm looking for another bike to mount this set up on, I'm not too found of the possible damage that the vibrations could do to my precious bike.
Here you can see the old craftsman weedwacker engine on the side of this thing. The mount isn't that visible, but you can see some of it.
It if ever stops raining here I'll get more pictures.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 08-10-2008, 07:41 PM
deacon's Avatar
minor bike philosopher
Default Re: SchwinnWacker first build, more to come
It looks good to me.... Has to be the most inventive mount I have seen lately.
Me and the Ebike
New Novel in progress blog...
Old 08-10-2008, 08:17 PM
I went this direction because I couldn't get the housing off the clutch. That *^&^%%^$ plastic just won't budge. My plan was to not reinvent the wheel and make a pretty typical set up. but that all went out the window when I tried to get that clutch out and I was worried about damaging it.. I may cut it out and rework it so it's more typical... We'll see how this works first. It feels a lot more sturdy than it looks if you can believe that.
MyMotoredBike.com
Flicker Page
Old 08-10-2008, 08:49 PM
deacon's Avatar
It looks pretty sturdy to me. If it isn't try adding corner braces.
Me and the Ebike
Old 08-10-2008, 08:52 PM
MrLarkins's Avatar
HS Math Teacher
what does it do to the balance?
Old 08-10-2008, 09:37 PM
it throws it off a little bit. Oddly enough it's not as bad as I expected. I'm not sure if it's not as bad because it's such a small bike- 16 inch frame (more like a 15 due to angle) or if it's just that I'm so heavy It's not even noticeable when not pedaling and the motor is driving.
MyMotoredBike.com
Flicker Page
Old 08-10-2008, 10:38 PM
Radmanfly's Avatar
Lightbulb Re: SchwinnWacker first build, more to come
Down inside my clutch housing was a torque head bolt, accessible through the square hole in the end of the housing, holding it to the crankshaft. Once thats loosened (it cannot be removed, the head is too big for the square hole) the housing comes off exposing the centrifugal weights.
www.farleysradiator.com
Old 08-10-2008, 11:12 PM
I guess I should specify- I was able to get the housing and the clutch bell off, able to see the weights etc, but the plastic housing that holds the bell and shaft won't separate. I'm assuming it's something like the other end of the shaft where it had a non removable sealed bearing and to get that out I had to cut the shaft.
As is it's runs just fine. I'm going to rework one of the brackets but so far so good.
MyMotoredBike.com
Flicker Page
  #9 (permalink)
Old 10-04-2009, 08:43 AM
Blakenstein's Avatar
that bike reminds me of an old Kona I used to have I like that style- nice rear mount but not very high on friction drives
