Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Motorized Bicycle Pictures
The SBP Jack Shaft rules !!!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Pictures forum. Sorry the post didn't work I highlighted it all into my browser please try again!!! I be much obliged. When ...
  #51 (permalink)
Old 05-06-2009, 12:31 AM
Goat Herder's Avatar
Default Re: The SBP Jack Shaft rules !!!
Sorry the post didn't work I highlighted it all into my browser please try again!!! I be much obliged. When I post extra links on this site? I copy and past so to speak . PM me for better description if it helps . I will probly post the way for it works here. Its sad some things are hard to explain. We for I know are here to fight the good fight! Thats why I love this forum so much. LOL. Just cought me tired. I am wore out let me know for help !!!!
One can do anything they set there mind to.... Do a good thing...
http://www.sdc.org/fattire/goatheads.html I get no flats..
  #52 (permalink)
Old 05-06-2009, 12:53 AM
I have found a good bit of 650 range it comes without the etc. bit . why would I do it just stay tuned.LOL God Bless Us All.......Lets Get Redly To Rumble lOL!!!!!!!!!!!!! Uh yeah I ride In The late words of All Bundie Lets Rock...........
  #53 (permalink)
Old 05-11-2009, 11:10 AM
I NEED HELP! i was getting ready to swap out my cartrige bottom bracket for the cup and cone one that comes with the kit and i realized i didn't have the tool to remove it. I tried using a screw driver and hammer to unscrew it but sticking the screwdriver in the splines at an angle and hitting it but it broke the splines. I got pretty frustrated and decided since this thing was plastic i could just break it apart. problem is it won't break. so the bottom bracket tool is useless even if i had one. What do i do? is the bike ruined?
  #54 (permalink)
Old 05-11-2009, 11:39 AM
Ghost0's Avatar
If you take it to your local bike shop they can have it removed in about 2 minutes. They should also have the bearing set you need.
www.sickbikeparts.com
  #55 (permalink)
Old 05-11-2009, 06:59 PM
lordoflightaz's Avatar
BTW chances are you tightening it not loosening it.
Bike shop is the way to go and you can pick up the silly tool there for like $10. If they sell Pyramid tools you might be able to get a neat little kit with a bunch of weird bike tools for $45 or less which includes that one, a chain breaker, and spoke wrench.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
  #56 (permalink)
Old 05-11-2009, 10:34 PM
Really the socket thats made for that is the Ideal way to go. On my install the factory used some evil lock tight it was a little rough. I wound up using an old race as a die too chase the threads. Had to use a hacksaw to cut relief grooves against the threads on the old race piece that I had lying around that matched the threads on the bike. Then with brake clean I got it . That was a pain in the but LOL Hope that helps someone!It doesn't take much to buger those fine threads. Then you are really screwed. Also its very easy to go the wrong direction.
  #57 (permalink)
Old 05-11-2009, 10:44 PM
The thread Direction is the same approach as the threads on the peddles.
  #58 (permalink)
Old 03-12-2010, 06:07 AM
otis's Avatar
so the pedals go on thier own and u gotta hold ur legs out?
STANCAC is my ps3 name, to chat bikes msg me
  #59 (permalink)
Old 03-12-2010, 06:08 AM
otis's Avatar
is it worth the annoyance and can u pedal without motor ingaged
  #60 (permalink)
Old 03-12-2010, 06:11 AM
BarelyAWake's Avatar
erm no - that would just be silly lol, there's a unidirectional freewheel bearing mounted to the pedal crank and it's sprockets - it's high quality one of the main reasons for the SBP kit's cost
HTML code is On
