| Sponsors
| | | | | Pictures and Videos Use this forum to share pictures and videos of your motor bicycle. | Pictures of my CH80 center mount, and rear mount tire roller bikes Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. Hi -
Attached are my pics.
Thanks collectively for your help with my center mount bike. It is running like a ...  |
05-25-2008, 11:07 PM
| | Motorized Bicycle Apprentice | | Join Date: Jan 2008
| | Pictures of my CH80 center mount, and rear mount tire roller bikes Hi -
Thanks collectively for your help with my center mount bike. It is running like a kitten now, after solving problems over the last 6 months re:
1. Engine mounts - ended slitting old inner tube and glueing it around both forks of V frame, to reduce vibration (and hopefully so studs won't break like they did the first time).
2. Enging mounting clamps - after 1st one broke, from this EBAY kit, got clamps from THATSDAX and they seem to be good.
3. Engine running rough at high revs - sucking air through carb mount, put permatek gasket on carb mount, runs good now.
4. Stripped head bolt - initially thought it was stripped stud (hey, everything else has gone wrong !), on closer inspection it was head bolt (whew). Bought some regular (open) bolts and was able to torque to 15 ft lbs - manufacturer suggests 21, but I am not confident yet. Engine is no longer seeping oil out of head gasket.
5. Rear tire bearings went on my old schwinn cruiser frame - Bought new rear wheel with heavy duty spokes.
6. Kept getting flat tires on my new wheel - bike shop guy showed me how to CORRECTLY put in inner tube, partially inflated so it doesn't krinkel up in the tire.
Got my wife and daughter riding the rear tire roller bike today - they like it !
Thanks again, please reply if you have any questions
cb |
05-26-2008, 12:07 AM
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes Nice ride's  Glad to hear you got everything worked out.  |
05-26-2008, 07:04 AM
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes I second that emotion!
07-05-2008, 10:38 PM
| | Motorized Bicycle Apprentice | | Join Date: Jul 2008
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes Where did you get the rear mount for the engine? |
07-20-2008, 10:38 AM
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes Sorry I took so long to get back to you, too many hobbies...
I got the rear mount from livefastmotors, put it on the bike in Fall of 2007
At this point wouldn't recommend it for reasons:
1. Needed to epoxy clutch drive cylinder to threads of tire roller, as it kept spinning off the roller when going down hills, locking up against the engine (!) - don't remember if I described this above.
2. Looks like the tire roller metal "teeth" are wearing out really fast. We have put maybe 300 miles on the bike and I don't think it should be wearing out so fast. I need to get a new roller at some point, and will need to get a clutch disk having epoxied it to the threads. Not sure at this point if I am even going to be able to get the tire roller out of the mount, having the disk epoxied on.
I have ridden this bike on some dirt roads, and on cinder (old railroad beds) wondering if this material is wearing off the teeth somehow. Anyone got experience with this ?
You should also look at Island Hoppers for rear mounts. Reasonable price, and I think they have been in business for awhile.
cb |
07-20-2008, 11:12 AM
|  | Master Motorized Bicycle Builder | | Join Date: Jan 2008 Location: Nor*Cal
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes Those are nice bars on our black bike. They seem wider than your standard BMX bars. |
07-20-2008, 08:03 PM
|  | Master Motorized Bicycle Builder | | Join Date: Dec 2007 Location: Essex, UK
| | Re: Pictures of my CH80 center mount, and rear mount tire roller bikes Quote:
cb | Using the right safety equipment I hope... in the last week alone i have been almost taken out three times. Im a convert to helmets now..
Glad they enjoyed it - you realise that if either of them get hold of the CH80 you will be bikeless  its that natural charm us girls have
Jemma xx
__________________ "....Look, no pedals... *thud*..." The mating call of the motorized-biker. "RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:21 AM. | | |
