| | | Pictures and Videos Use this forum to share pictures and videos of your motor bicycle. | o.c.c vs w.c.c (chopper vs biker) Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. the first stage of the o.c.c build is done the forks and the kick stand are done we ...  | |
04-21-2009, 07:00 PM
|  | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: elgin,il
| | o.c.c vs w.c.c (chopper vs biker) the first stage of the o.c.c build is done the forks and the kick stand are done we tired to do the seat but the seat post bent so we have to come up with a new design for seat the w.c.c build will start in the next few days
for more info on the build check out the web sit Home ?(west coast vs east coast)?
leave some tips or questions if you wont
life to short so lets ride
04-21-2009, 07:36 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: penn state
| | Re: o.c.c vs w.c.c (chopper vs biker) Quote:
Originally Posted by outlawchopper the first stage of the o.c.c build w.c.c build
for more in for check out the web sit |
lotsa abbreviations that are lost in the translation here ??????
For when it is to rainy and cold outside to play with my bike . I go here |
07-19-2009, 09:05 PM
| | Re: o.c.c vs w.c.c (chopper vs biker) Orange County Choppers (American Chopper T.V. show) and West Coast Choppers (Jesse James, I think, right?)
07-19-2009, 10:00 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jun 2009 Location: Minnesota
| | Re: o.c.c vs w.c.c (chopper vs biker) Awesome job on the forks. I was wondering if someone was ever going to make a stretched look for that bike.  |
09-05-2009, 01:30 AM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: utah
| | Re: o.c.c vs w.c.c (chopper vs biker) I just bought a WCC bike like yours, and would like to put a motor in it (wondering what is best). I know almost nothing about bicycles, but I know lots about motorcycles. Just built a full size chopper with a 107 S&S motor and a yr ago rode it a 1000 miles in a day and a half back from Sturgis. So I ought to be able to motorize this WCC bike.
Mind if I take lessons from you guys?
Guess I need to introduce myself (will right after this post) |
09-11-2009, 11:36 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Central Missouri
| | Re: o.c.c vs w.c.c (chopper vs biker) I do not have a WCC, have only seen them in pictures. I do have an OCC, and I changed out the forks with the rare set that has front brakes and a 20" tire. Also replaced the handle bars, added a dual cable brake lever, and reduced the seat post size by way of sleeve inserts to 1" to accommodate a lay back seat post and a 13" coil cushioned seat. Compliments to Bike Barry for the motor mount and the exhaust pipe and to Manic Mechanic for the rear sprocket and sprocket adapter! |
09-12-2009, 03:29 AM
| | Motorized Bicycle Senior Member | | Join Date: Mar 2009 Location: elgin,il
Originally Posted by 2wheelcowboy I just bought a WCC bike like yours, and would like to put a motor in it (wondering what is best). I know almost nothing about bicycles, but I know lots about motorcycles. Just built a full size chopper with a 107 S&S motor and a yr ago rode it a 1000 miles in a day and a half back from Sturgis. So I ought to be able to motorize this WCC bike.
my buddy (outlawchopper) doesnt have net right now so allow me to tell you the nightmare which we had to go thru to get his up and running.
first off the cheapest engine kit we could come up with was an 80cc black slant head from boygofast. however,they shipped the wrong engine,we received a standard 80cc silver engine kit and we didnt have time to argue and fuss about it,we just had to make due. i dont have chopper's permission to release photos at this time but i can tell you right now,if you are doing this on a budget and cant afford custom machined parts your going to have to design and weld up a custom motor mount, either cut the crank and weld an extension on it to clear the engine or hope a 3 peice crank will be wide enough to clear the engine. also for the chain to clear the frame and bulbous tire on this bike was a miracle of trial and error, we still have yet to perfect it,but it works well enough for now. we had to ditch the coaster brake hub and rim cause the stock spokes wont accept the 9 bolt thru the clam shell adapter also the coaster brake is in the way even after heavily modifying it. we used a freewheel and made custom brakes.
currently i dont know of anyone who has custom machined parts available to make the engine install any easier but you might want to contact creative engineering MANIC Mechanic Parts.htm he might have something available or can make something.good luck. |
09-12-2009, 10:24 AM
Originally Posted by saetta I do not have a WCC, have only seen them in pictures. I do have an OCC, and I changed out the forks with the rare set that has front brakes and a 20" tire. Also replaced the handle bars, added a dual cable brake lever, and reduced the seat post size by way of sleeve inserts to 1" to accommodate a lay back seat post and a 13" coil cushioned seat. Compliments to Bike Barry for the motor mount and the exhaust pipe and to Manic Mechanic for the rear sprocket and sprocket adapter! | I like your bike! Can you tell me where you got the brake cables? I'm running into the problem where the cable is too short with the ape hangers. |
09-12-2009, 03:20 PM
| | Re: o.c.c vs w.c.c (chopper vs biker) Thank you. I purchased the brake cables from a local bike shop and the cable housing is sold by the foot. The dual brake cable lever was a big plus and is the tension to either brake is of course fully adjustable both at the lever and the brakes. Sitting back as far as I now do makes for an un-cramped ride and this seat absorbs most of the road bumps.
09-13-2009, 07:17 AM
| | Motorized Bicycle Newbie | | Join Date: Feb 2009 Location: Sunny florida
| | Re: o.c.c vs w.c.c (chopper vs biker) Offset motor mount is available on Ebay | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:28 AM. | | | Sponsors
