Next La Jolla Revamped lmao!
Bobert
Ok So it's been a few months since the last post I've made... Well I did finally get my motor, It did fit with some moditfications. I wasn't smart enough to take pictures when I was doing them but I do have the afterwards lol. Except for the Intake which I am waiting on right now.... It was Aluminum, and I don't have the right equipment at home to weld it, so I took it to a friends shop. I'm having him make the base plate made out of mild steel, So I can work with it. I will be fabricating a new intake, and possibly a dual intake for s's and g's...... I should have the piece this week. Any ways here are some updated pictures of the build..
Ok here's a run down of what I got and what I'm doing or have done....
Bike - Next La Jolla street cruisier...
Motor - Jet Stealth 80cc w/slant head. (it's better to get the Silver and Paint it Yourself)
Modifications - First and formost, The intake has to be completely redone, and I had to cut the front engine mount, and the pedal crank is barely clearing the muffler.
Intake - Is made from Aluminum, I can't work it at home. So I'm doing it out of mild steel. I have a 3/4" pipe (ID) for the actual intake and a 3/16" thick base plate. I will have pics during fab and when finished.
Engine Mount - I do have pix of the finished product. I had to take off about a 1/2" but it fits in place better now :)
Muffler - As for this I'm going to see how well it goes, and if I need to I'll go with the poo poo pipe or see about fabing something else up.....
All that being Said When I finish the Intake and it works out alright I might be able to make some more of them just let me know.........
Now for the pictures, I have more so I will put another post up to finish all of them....
Pic #1 a loose fit of the Motor after We got the sprocket on and the wheel trued. All the little things are there too!
Pic #2 & #3 are of the Modified Engine Mount, I did pull off about a 1/2" and It gave me more clearance.
Pic #4 & #5 Are of the little bit of clearance I had with my frame and the intake.... I sanded it so melted paint wouldn't get into the motor..... Well I don't need it anymore lol....
Next pix on Next post!
Here are 5 more pictures........ I did run Into another clearance Problem.... the Clutch Arm, We ended up having to cut it, but It doe work great!
Pic #1 Shows the clutch arm before We modded it it hits the frame and doesn't allow the clutch to disengage
Pic #2 I'm sorry that it's not all about the clutch, I was trying to get the back wheel and the Chains. It does show the modded clutch and I will have another pic of just the clutch if needed :) I do like my new pedal drive chain though lol.
Pic #3 The Clearance of the muffler and pedal cranke is sub 1/8" lmao, I really think It'll be ok but if not I can do something different.
Pic #4 & #5 Are the finished Product Minus the Intake, Which I am still waiting on lmao.... I should have the piece sometime this week and I will be finished and ready to ride this weekend if all goes well!
Other modifications not shown...
5X thick Slime tubes
Inline fuel Filter
Side note, It is able to stand freely with the stock Kickstand.... Just figured I would say that.
Please give me feed back and let me know what you all think about what I am doing, I'm very interested and Will use any advice if able!!! Thank you everyone for taking your time to check my progress!!
I would get rid of that rubber you have in the mounts... It will cause problems down the line.
Also, you can 'slot' the mounting holes in the pipe & turn it out of the way of the pedals!
Good luck!
