Originally Posted by Pablo Maybe I missed it but have you ported both manifolds? This makes such a HUGE difference it's best to do this first before you tune the carb, etc. It's very easy with a Dremel and couple 6 packs of smaller size sanding drums, one of 80 grit the other 120 grit. There is terrible flange mismatch and intake has weld and plating obstructions. |
Yep one of the first things I did when prepping the engine for installation. They were so off I estimated the exhaust was blocked by 25% the intake a little less. Did you have time to look at your silencer? Mine is packed with white mterial maybe fiberglass Im not sure. It is awful loud, and I read yours was too. Curious what you did or are going to do.. Love the Sabre, just started using it....
