Originally Posted by RedB66 The connection into the air cleaner is Nitrous. I connected the air cleaner by mounting 2 large (same circumfrance as carb) washers onto the carb and then mounted the rubber fitting from air cleaner over them. Tightened down with existing clamp. |
Interesting that you've nitro'd the chengine - what performance increases have you noticed and how have you solved the lean-out problem ?
I love the frame, do you know if there is a UK supplier for it?
Jemma xx
