| Sponsors
| | | | Pictures and Videos Use this forum to share pictures and videos of your motor bicycle. | Michigan Wolverine Bike Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. hello from owosso michigan (m-go -blue) what better way to go!...  | |
08-18-2008, 11:09 AM
| | Motorized Bicycle Builder | | Join Date: Jul 2008 Location: owosso michigan
| | Re: Michigan Wolverine Bike hello from owosso michigan (m-go -blue) what better way to go! |
08-18-2008, 05:19 PM
| | Senior Motorized Bicycle Builder | | Join Date: Jun 2008
| | Re: Michigan Wolverine Bike Quote: |
Nice build, I would suggest moving the shifter to the left side of your handlebars though. It is tough to modulate the throttle and shift at the same time with the same hand.
| i was thinking that same thing, cause the 'reach over' shift method is fairly awkward, sure can;'t shift like that bike in the queensryke,(can't spell) vid
"You must cultivate the feeling that a warrior needs nothing"-don juan |
08-18-2008, 05:31 PM
Is kick starting still fairly easy with the kit? you know, the whole "pick back of bike up, push on pedal to spin motor and start bike" routine....
| with a new, tight engine it's still hard to start for me. don't have enough power to 'kick, like a dirtbike, but like ghost0 suggests, rolling along, stand up and kick down 3 or 4 times.
btw, you got a good ride to work (video) jasonh, looked like rainy weather in the video
08-18-2008, 07:44 PM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Michigan Wolverine Bike being from michigan i give this bike a 5555555555555 that's a high five! nice job. looks awesome  |
08-18-2008, 07:52 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: Michigan Wolverine Bike You almost have the start process down however I must caution you against "kicking" down to start it. That puts a lot of stress on the front freewheel that it was not designed for. I will try and explain my method clearly. Yes get the bike moving at a decent pace in 1st gear, prop the crank for your preferred leg up at about 45 degrees, get off the seat and put your weight on the pedal of that crank, as it starts to turn I get back on the seat and just keep pedaling through. Once the engine starts to turn over it is pretty easy to continue pedaling. Hope this helps. Good job on the install BTW, nice looking ride.
Just an FYI Queensryche |
08-28-2008, 02:02 PM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: Michigan Wolverine Bike GO BLUE!!!! Nice bike shiloh0, a Spartan could not have done better....Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
08-28-2008, 03:06 PM
|  | Master Motorized Bicycle Builder | | Join Date: Apr 2008 Location: Valparaiso, IN
| | Re: Michigan Wolverine Bike Hail to the Victors!!!!
I feel the pleasant penninsulas calling me home.... | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:03 AM. | | |
