| | | Pictures and Videos Use this forum to share pictures and videos of your motor bicycle. | imp's rebuild Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. ok, so here we are with another build of mine after more sheared bolts.
Here i have an engine from ...  | |
10-22-2009, 04:47 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: australia
| | Re: imp's rebuild Nice 1 bro! now hurry up and finish, we go cruising.
As for the magnet nut, on my old motor i jammed something between the magnet and the magnito frame like a screwdriver. Im sure theres a propper way to get it off,i just dont know it. |
10-22-2009, 04:52 AM
| | Motorized Bicycle Member | | Join Date: Sep 2009 Location: modesto
| | Re: imp's rebuild very nice build, I dig the bracket you made for the down tube, I went the easy way and drilled my frame.. wish I hadn't lol.... good work man  |
10-22-2009, 05:08 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Syadney,Australia
| | Re: imp's rebuild Quote:
Originally Posted by omegaunderground very nice build, I dig the bracket you made for the down tube, I went the easy way and drilled my frame.. wish I hadn't lol.... good work man  | yah, the downtube bracket/plate is actua;;y a pice cut off from bunning's scaffolding that they use in the store :P
took about 30mins to cut through it with a hack saw... bloody dense !@#$ that stuff
also i left the fold there ( above the engine mount point ) as to give it horizontal strength on the top end of the plate, also helps in not letting the engine flex from side to side |
10-22-2009, 05:10 AM
Originally Posted by stv1jzgte Nice 1 bro! now hurry up and finish, we go cruising.
As for the magnet nut, on my old motor i jammed something between the magnet and the magnito frame like a screwdriver. Im sure theres a propper way to get it off,i just dont know it. | yah, just need to get that nut off so i can get the pull start installed as kicking over the engine by foot is not a good idea with a shift kit... i sheared 2 bolts in one go by doing that on my first ride at a set of lights i had the idle a bit low |
10-22-2009, 05:42 AM
Originally Posted by impression yah, just need to get that nut off so i can get the pull start installed as kicking over the engine by foot is not a good idea with a shift kit... i sheared 2 bolts in one go by doing that on my first ride at a set of lights i had the idle a bit low | Dude grab flat headed screwdriver in ya left hand and a ring spanner in the other, the Magnet sorts looks liike the batman symble yeh, poke the screwdriver (vertical) in through the front left of the crank NOT THE SIDES.
when you turn the spanner it will all lock up and she should wind off. |
10-22-2009, 02:54 PM
| | Re: imp's rebuild Dooood... It's not a good idea to run your carb that far out of level. |
10-23-2009, 09:42 PM
| | Re: imp's rebuild ok, went for test ride today, went about 25km from home and chain broke aswell as a nut came off my front mount bracket and the allen bolt in the middle collar of the shift kit's drive shaft came out somewhere along the way.
replace nut > check
fix wide open throttle proglem > check
fix high idle > half a check, still a bit high.
replace allen bolt in collar > to do
replace broken chain link > to do |
10-23-2009, 09:54 PM
| | Re: imp's rebuild Be careful trying to remove the magneto magnet. The crankshaft is only about 5/16" diameter at that point and it will bend easily if too much lateral force is applied. Use two large flat blade screwdrivers and 'wiggle the magnet off the shaft. Don't get heavy handed or you'll be replacing the crankshaft. There is a crankcase seal behind the magnet; don't damage it.
Over Youth and Skill | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 01:54 AM. | | | Sponsors
