Hi,
I've made a major change to the bike today. Basically I have reversed the headset on the bike and redone all the controls to suit.
The only problem I have run into with this setup is knees and handlebars when pedalling slowly (from stop), they tend to collide...
and manuvering the bike is harder because the end of the bars hit my legs - this should be solved by moving the seat back further (which means a new seatpost
I've also moved the storage bag I had on the bars to the RHS of the bike using the GEBE mount to put it on the bike. I *might* be able to fit another bag on the other side.
My fuel tank is leaking slightly from the top bolt mounting on the RHS of the fuel tank but I cant see a leak anywhere - is there anything I can use to stop it?
Comfortable cruise is now 31mph and the bike will wind out another 4-5mph above that WOT.
Pictures are attached
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
