Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Pictures and Videos
Ghost0's MB Cruiser
Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. Originally Posted by VENICE BOY Well, my total fasination with top speed is the fact that we ride in very ...
  #11 (permalink)
Old 05-04-2008, 10:17 PM
Pablo's Avatar
Amsoil Dealer
Default Re: Ghost0's MB Cruiser
Originally Posted by VENICE BOY View Post
Well, my total fasination with top speed is the fact that we ride in very fast Los Angeles traffic... and I pesonally feel that it's much safer to be able to keep up with it.
Gotcha - hmm...well if your top speed gear on your rear hub is nice and high and you get a nice tall gear on the right of the shaft 50+ mph!!!!!!!!!!
http://oilslubesfilters.com/
  #12 (permalink)
Old 05-04-2008, 10:42 PM
VENICE BOY's Avatar
Custom Builder / Dealer
Sounds great!
After watching that "death race" video 500 times... ... I think I'm ready!
But seriously, post how fast you actually can make one go!
Check out www.VeniceMotorBikes.com
  #13 (permalink)
Old 05-25-2008, 01:48 AM
Motorized Bicycle Apprentice
How do you tension the chains between motor/jackshaft and jackshaft/bottom bracket?
Keith
  #14 (permalink)
Old 05-25-2008, 08:04 AM
Pablo's Avatar
Amsoil Dealer
The engine mounts. Pretty easy. Here's what we currently have in the manual:
Step 10
Right side chain installation
Your engine should be loosely mounted to the frame at this point. The front stock mount should be very loose and the U-bolts on the rear mount should be just loose enough to allow the engine to slide along the seat tube.
1.Force the engine down as far as you can by pushing on the rear mount. Make sure the U-bolts are not getting hung up not allowing the motor to move.
2.Drape your new bike chain over the small sprocket with one end of the chain hanging about 4 inches down toward the rear of the bike. Wrap the remaining chain around the large chainring and up to meet the other end. Now you need to decide how much chain will need to be removed. It may be better to go too short at this time than too long, however never overly force the chain on, you can damage the chain and the freewheel..
3.Shorten your chain as required and install. The best method for this is to fully assemble the chain, place it inside the chainrings and onto the small sprocket. Once it is on the small sprocket, start placing it on the large chainring and slowly start turning the cranks until the chain has been installed. It will take some force to do this and your clutch on your engine will need to be disengaged so that the sprocket can rotate.
If your chain is loose after it has been installed, it may be too long. If it is only a little loose you may be OK, it needs to stay on with not too much slack but not be tight.
Adjust your rear mount to tighten the chain if it is a little loose. When you start running your bike, the force on the motor will twist it slightly and loosen the chain. You will find that you will probably have to adjust your rear mount 2 or three times until everything settles and the chain will remain tight. Remember to loosen your front mount substantially before trying to adjust your rear mount.
NOTE: never overtighten the chain, it can cause damage.
Tighten your rear U-bolt mounts and your front mount. Ensure that the chain remains tight.
Remove the set screws from the small sprocket, apply thread locking material and tighten the set screws.
  #15 (permalink)
Old 06-08-2008, 11:14 AM
Easy Rider's Avatar
Whoaaa!!!!
That's one nice bike GhostO!
I'm going to check out more on your jackshaft Idea on how you've got the cranks not to spin with the engine. Major props!
Similar Threads
My Kulana Moondog cruiser first fitup 48cc motorbiker Pictures and Videos 25 06-04-2008 09:40 AM
Jaguar Beach Cruiser TINKERER Pictures and Videos 10 05-10-2008 05:52 PM
cruiser's cruiser with a bicycle engine CRUISER Pictures and Videos 11 03-09-2008 08:35 PM
My Two-Stroked Motorized Schwinn Cruiser Bean Oil Pictures and Videos 6 02-24-2008 06:58 AM
