| Sponsors
| | | | | Pictures and Videos Use this forum to share pictures and videos of your motor bicycle. | chain tensioner Discussion at Motorized Bicycle Engine Kit Forum in the Pictures and Videos forum. just wanted to share a few pics with all of you of the tensioner i fabbed over the weekend. I ...  |
06-01-2008, 10:37 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Decatur,IL
| | chain tensioner just wanted to share a few pics with all of you of the tensioner i fabbed over the weekend. I used a roller skate wheel I got for free from the local roller rink , then I modified a bmx brake arm with a internal spring , then fabbed up a new bracket, and had cut up the stock mount, modified it then re-used it as the bracket clamp ! a little paint to clean up the roller skate wheel and a few new bolts with acorn nuts for decoration and tweak here and there and wa-lah , the perfect tensioner. I appreciate so many who have replied to me about a tensioner and sharing ideas, that I have come up with my own application that works for me. hope you enjoy!
I'll keep rollin "FileStyle"
"ever notice someone going slower than you is a idiot and someone going faster than you is a maniac" George Carlin
06-01-2008, 11:42 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: chain tensioner Very clean, very professional looking!  |
06-02-2008, 06:23 AM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: chain tensioner Nice!!!!!!
06-02-2008, 08:26 AM
| | Re: chain tensioner Shizznits!
cool. |
06-02-2008, 07:13 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Montreal, Canada
| | Re: chain tensioner I LIke, I Like It!!!!! |
06-03-2008, 09:42 AM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: chain tensioner Excellent job, but I do have one suggestion. Typically most chain tensioners will have their pivot points leading, and the roller trailing, the direction of the chain rotation. Your roller is leading and your pivot point is trailing. Would be real simple to just turn the unit around. I doubt you will experience the potential over center problem but something to keep in mind. |
06-03-2008, 12:14 PM
| | Re: chain tensioner Good tip...I was gonna say that, but it looked so nice, I thought I'd let it go.
I AM the one who, on my first build mounted his chain tensioner on the upper run and was perfectly happy with it until someone pointed it out....It did work better once I put it where it belonged though.
06-03-2008, 12:25 PM
| | Re: chain tensioner the set up works good as is , as long as no one tells the chain that!(the chain doesnt know where the pivot is at!) but thank you for the advice I may turn that around just to see if better or not!
06-03-2008, 02:19 PM
| | Motorized Bicycle Apprentice | | Join Date: May 2008
| | Re: chain tensioner How did you make it and with what parts and where can you get them? |
06-03-2008, 03:37 PM
| | Re: chain tensioner a roller skate wheel , free from my local roller rink ; a used brake arm from my personnel stash of goodies and then fabbed up a new bracket. the brake arm was used originally for a brake that mounts on a post on the frame of a bike, it has the small round spring inside that you can mount in different holes for the type of tension that you needed for your brakes. when I fabbed the new bracket , I drilled a 5/16" hole in the bracket ; then drilled a series of 1/8" holes around the larger hole for different tension settings and located the spring to the hole which best suited my needs. On both points (roller/pivot) I used 5/16" bolts with nylon locking nuts then decorated with acorn nuts. the little system works really well to my application.(necessity is the mother of invention)
well thats about every thing in a nut shell , if you have more questions feel free to ask
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:29 AM. | | |
