| Sponsors
| Our Forums | | | | Motorized Bicycle Pictures Use this forum to share pictures of your motor bicycle. | Another schwinn Jaguar Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Pictures forum. I have about 5 miles on the bike, and I am pleased so far. This has been a fun project ...  |
05-29-2009, 08:39 PM
|  | Motorized Bicycle Member | | Join Date: Mar 2009 Location: Chicago
| | Another schwinn Jaguar I have about 5 miles on the bike, and I am pleased so far. This has been a fun project and also a fun ride, It's not completely finished and I have room for improvement in several area's but its close enough to start getting some break in time.
myke
__________________ Schwinn Jaguar, 80cc It's Better to be a demonic then a trivial person... http://hit-da-pipe.com |
05-29-2009, 09:32 PM
| | Re: Another schwinn Jaguar Myke,
Everyone knows I'm a big Jaguar fan and when I see another example as fine as yours its easy to see why. I hope you enjoy it as much as I do mine. It's a sweet, comfy ride and yours looks like it will easily compare with all the others. Love the springer, front hub and the lay-back seat post. Congrats and if you don't mind I'd like to add your Jag to my collage which I'll be updating soon.
Over Youth and Skill |
05-29-2009, 11:58 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: independence missouri
| | Re: Another schwinn Jaguar very nice i like the springer and the bags
stay thirsty my friends
05-30-2009, 08:03 AM
| | Re: Another schwinn Jaguar Quote:
Tom | Thanks for the compliments, sure add me in there with the rest. I am also keeping a more detailed record of the experience on my own site, you might find some other photo you like better. I did not want to bore all the users here with the details. Hit-da-Pipe.com: Forums / Moterized Bicycles
myke
05-30-2009, 08:34 AM
| | Motorized Bicycle Elite Member | | Join Date: May 2008
I just finished a Point Beach and it needs a Laid back seat post. Where did you get yours?? All the ones I've seen are too small. (I have a 1 1/8" or 28.6mm post.) |
05-30-2009, 10:52 AM
Originally Posted by captainrichhill Myke,
I just finished a Point Beach and it needs a Laid back seat post. Where did you get yours?? All the ones I've seen are too small. (I have a 1 1/8" or 28.6mm post.) | Mine was too small also, so I cut about 4 inches off the original and then cut a slot in it, and used it as a spacer. The smaller ones fit right inside the 4 inch part of the original and tightened up perfectly because of the slot. This moved the seat back quite a bit, but it could go back even more with a custom seat or post, I have yet to come up with a better design.
In addition to this I cut the handlebars off about 3 inches on each end, I think I can cut another 3 inches off if I use a thumb shifter in place of the twist shifter that takes up less room on the right side of the bars.
myke
05-30-2009, 02:06 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: Another schwinn Jaguar nice looking jag !!!
be carefull of your stem, it looks like it is extended up too high
I cut 2" off each end of my bars as well  |
05-30-2009, 09:53 PM
Originally Posted by myke Mine was too small also, so I cut about 4 inches off the original and then cut a slot in it, and used it as a spacer. The smaller ones fit right inside the 4 inch part of the original and tightened up perfectly because of the slot. This moved the seat back quite a bit, but it could go back even more with a custom seat or post, I have yet to come up with a better design.
myke |
Myke, and Capt. Rich,
My Jag had a 1" seat post tapered to 7/8" where the saddle mounts. I used an 18" section of 1" cold rolled bar stock, turned 6" of one end down in a lathe for my seat post. It gives me plenty of lay back and improved the comfort a lot. The Jag is short of leg room and the lay-back post is almost a necessity for anyone over 5" tall. I'm 5"11" and this mod made my Jag a way comfy to ride.
05-31-2009, 02:04 PM
Tom | Thanks for the idea, I may have to try a piece of 7/8 round stock bent with my home made spacer since I don't have access to a lathe. With any luck the heavy round stock may also dampen some of the vibration.
myke
__________________ Schwinn Jaguar, 80cc It's Better to be a demonic then a trivial person... http://hit-da-pipe.com | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | All times are GMT -5. The time now is 01:48 PM. | | |
