| | | Introduce Yourself Welcome biker. We'd love to hear your story and let us know about your motorized bicycle projects! | Suggestions about shifter kit Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. Hello my name is Vlad im fairly new at these chinese motorized bikes got my first 1 about a year ...  | |
10-15-2009, 12:25 AM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: Brampton
| | Suggestions about shifter kit Hello my name is Vlad im fairly new at these chinese motorized bikes got my first 1 about a year ago, im curently on my 4th and each one getting better by the day. I wanna try out a shifter kit with a 80cc preferably a ch80(wondering if anyone has any reviews about that engine) and a shiftet kit from SBP, i was wondering if anyone on this site has tried any of those and if so if you could give me some feedback on them as it will be a litle pricey  |
10-15-2009, 12:40 AM
| | Motorized Bicycle Member | | Join Date: Aug 2009 Location: South Australia
| | Re: Suggestions about shifter kit SBP shift it is the single best mod you can do to your HT in my opinion. Mines hooked up to an "80cc" as well and I love it. Done 1000kms riding with it now and has been more or less faultless. I'm running the standard freewheel as well and a crappy cup and cone BB. The new HD deluxe kit and sealed cartridge makes me so jealous! |
10-15-2009, 09:36 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: Suggestions about shifter kit are you from Brampton, Ontario ???
I am a displaced ontarian living in the desert
we are getting a lot of members from the golden horseshoe !!! |
10-19-2009, 01:04 AM
| | Re: Suggestions about shifter kit well that gives me some motivation to start on this project so would you recommend that i buy the hd delux, your really think its that much better then the regular shifter kit? and my #1 concern was if the free wheel happens to fail on me ill b stranded were ever i m and not be able to pedle back or do anything correct? and to answer Bill's question yes Brampton Ontario unfortunetly were in the dessert are you from Bill? |
10-19-2009, 05:57 AM
| | Re: Suggestions about shifter kit Well, I don't have one yet but I see that the HD and HD deluxe kits include a heavy duty freewheel and assorted tools for removing the pedal crank, for the small extra amount of money it couldn't hurt to have the peace of mind
There's those that have run the standard kit with no problems, so it's up to you - awsome kit all around though! |
10-19-2009, 12:18 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Ontario
| | Re: Suggestions about shifter kit ill be buying the hd kit soon enough, it comes with the dual pull brakes (if your running an mtb) and other things that are useful. plus the HD freewheel is servicable.
i hear only good about the kit it has been very well designed and preforms without clutching between gears.
really helps the life of the little chinagirls since they dont have to work as hard
<code>"isuck@code"</code> |
10-19-2009, 08:05 PM
| | Re: Suggestions about shifter kit I have a HD Shifter kit. Highly recommend the HD version. It is really easy to kinda hit a shift hard. The slight slack in two different chains between the motor and the freewheel can bang it pretty hard. Like you said if you strip the freewheel you can't even pedal home. There is a small learning curve to getting the motor started with one. Overall they are awesome. No left side chain and sprocket. No tensioner. Easy takeoffs, climb any hill a car can. Better top speed without over rpming the motor. Add a expansion chamber and you will be a very happy camper.
__________________ Put something FUN between your legs.. |
10-20-2009, 12:54 AM
| | Re: Suggestions about shifter kit You make a good point about some peace of mind for a couple extra bucks, im assuming you need to use a quality derailer and gear set for the bike to handle the smashing gears but that sounds pretty fun, also have u ever tried a 4 stroke, im afraid to try it because i weigh about 210 pounds and i found the 49 cc strugled were the 66 does fine so i figure a 49 cc 4 stroke can only b worse off than the 49cc 2 stroke? |
10-20-2009, 04:18 AM
| | Motorized Bicycle Member | | Join Date: Sep 2009 Location: Australia - Melbourne
| | Re: Suggestions about shifter kit To end all discussion - i've past the 2000 kilometer mark on my SickBikeParts Shift kit and it's running perfectly.
You are simply wasting your time trying to run a single speed system, completely wasting your time.
Get the Delux kit as it comes with the heavy duty free wheel bearing; dual pull brake lever and an assortment of very handy tools needed to do required maintainace.
I only got the delux kit because i couldn't buy a Super-Duty Platinium Mega Kit.
The heavy duty freewheel bearing is rebuildable.
Fabian
10-20-2009, 04:39 AM
| | Re: Suggestions about shifter kit I bet $1 you'll not be able to "end all discussion" anywhere on this forum Fabian  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:19 AM. | | | Sponsors
