Thanks all for the anwsers,
Here are the info about the engine :
Hubvolumen / Cylinder capacity / Cylindrée 85 ccm / 5.09 cu.in
Leistung / Power / Puissance 9,2 PS / HP / CV; 6,76 kW
Bohrung Æ / Bore dia. / Alesage 44 mm / 1.73 in
Hub / Stroke / Course 28 mm / 1.10 in
Drehzahlbereich / Speed range / Vitesse de rotation 1200 - 8000 min-1 / rpm
Gewicht / Weight / Poids 2880g / 6.05 Ibs - incl. Zündung / ignition
Kurbelwelle / Crankshaft / 3 Kugellager / 3 Ball bearings / 3 Roulement à billes
Pleuel / Connection rod / Bielle Nadellager an beiden Enden / Needle bearings on both ends / Roulement à aiguille aux deux cotés
Benzin / Gasoline-Version 1 : 50 - 1 : 80 Mix
IIS - Zündung / IIS - Ignition / V.cc allumage 6,0 V
Propeller / Hélice 2-Blatt / 2-bladed / à 2 pales:
24x10; 26x8; 26x10; 26x12; 28x10
3-Blatt / 3-bladed / à 3 pales:
22x12; 24x10; 24x12; 25x12
[IMG]
[/IMG]
