Newbie from Rochester: Dax Engine?
Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. Well, my story is a bit interesting. I joined the electric bike club at my school, which is still in ...
Old 10-15-2009, 01:08 AM
Default Newbie from Rochester: Dax Engine?
Well, my story is a bit interesting. I joined the electric bike club at my school, which is still in its new stage. The club didn't have a clear goal, but decided that each member should have an electric bike. They were to all be the same, and would cost $350 each for parts of unknown quality. Well, that seemed a bit steep, and when I heard them mentioning batteries from junked lawnmowers... . I had been hoping for a club that would focus on building one really nice bike, like the BSEET department here did. After the plans were drawn up, the president had decided on using a modified bmx platform, with a rear hub motor, toggle switch/relay, and used batteries. The pedals would have to be removed with this setup. A little expensive for the estimated 8 mile range. Well, the idea of having a motorized bike was appealing to me, and I started looking for used parts to do my own on craigslist, and came across an add for a boygofast engine, new, asking 90. I realized that with my budget in mind, a small gas engine could provide more cost effective service. I did a little research of my own, and found that trying to cheap out a few bucks with no one to go to for service probably wasn't a good idea, and am now on this site looking for recommendations of a company to go with. I'm going to be mounting it onto an older huffy, with an internal 3 speed in the back. I have already mounted a front suspension fork from an old Rockhopper onto it, allowing me a knobbier tire (already ice up here!) and v-brakes. From everything I've read, for a small (80cc) 2 stroker, I should go with Grubee, and I should buy from Dax. Is Dax's F80 kit a Grubee? I'll hopefully be placing my order tomorrow.
Old 10-15-2009, 06:51 AM
BarelyAWake's Avatar
Default Re: Newbie from Rochester: Dax Engine?
Dax is an extremely reputable and friendly dealer - I would recommend just givin' him a call
Grubee Starfires are one of the higher quality kits, but this is primarily about what optional accessories are included and their quality - most of the engines themselves are almost identical regardless of what they're called.
The ones from Dax aren't actually Grubee kits - but I've heard his have slightly better construction, larger wristpins & better bearings if I'm not mistaken...
In any case Dax will take care of ya - and that's a fact
Good luck with your build - sounds like you've the right idea!
Old 10-15-2009, 07:06 AM
Alright, thanks! I'll be giving him a call today!
Old 10-15-2009, 10:42 AM
Bikeguy Joe's Avatar
Just be advised that your 3 speed hub may present some problems with mounting the sprocket.
You can always machine out the center of the sprocket, or find a 1 speed wheel.
Old 10-15-2009, 12:58 PM
Yeah, that's already taken care of. This morning I was playing around with SolidWorks, and have a custom sprocket that will mount. I'll just need to check the tooth pitch/spacing against the one in the kit, and then machine it.
