| Sponsors
| | | | Introduce Yourself Welcome biker. We'd love to hear your story and let us know about your motorized bicycle projects! | New here. Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. I do use the choke and the tickler. I put the choke lever about 3/4 of the way up, ...  | |
04-12-2008, 10:58 AM
|  | Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Norhtern Ky
| | Re: New here. I do use the choke and the tickler. I put the choke lever about 3/4 of the way up, and push the tickler about 5 times I guess. The hill I live on is about 150 yards from where my apartment is to the bottom of the hill and I pedal up to speed and let go of the clutch about 8-10 times before I get to the bottom of the hill. Sometimes it doesn't even start by then and I have to go even farther down another road to get it to fire up. It doesn't seem right to me. |
04-12-2008, 11:13 AM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: New here. I think I would check your spark plug next. With the carb problems you had at first you may have fouled it. |
04-12-2008, 11:27 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: New here. a new plug wire made all the difference in the world on my motorized bicycle for starting. you may want to change out the stock one if you haven't already. i was like you and had to go aways for the bicycle motor to start. now it pretty much fires up the minute i release the clutch if choke is on |
04-12-2008, 03:28 PM
| | Re: New here. I still think your bicycle motor has an air leak.
04-12-2008, 06:42 PM
| | Re: New here. Im going to come down with joe. If it ran at all with that much fuel being dumped into the carb had to be mixing with a heck of a lot of air.
Air leaks makes them hard to impossible to start. At least it did mine. But the most likely spot is the manifold tube. If you sealed that and haven't removed the engine manifold bolts you should have it taken care of. It might be a spark problem, but my feeling is air leak. |
04-12-2008, 07:26 PM
| | Re: New here. Check your gasket (or better yet, make a new one). If you can get some "Seal-All" or RTV gasket sealer, coat a LIGHT coating on both sides of your present gasket and see what happens.
04-13-2008, 01:13 AM
| | Re: New here. I spent about two hours tweakin the thing today. I replaced the plug with a champion L86C, I used RTV to seal the intake tube, and(what I think made the biggest difference) took the clutch plate cover off and tightened the star nut about three revolutions. It made a HUGE difference in how the thing runs. Starts right away, doesn't die when I pull the clutch lever in, and slows down when I let off the gas. When I come to a stop sign or intersection I need to stop at, I don't have to kill the engine and pedal a bunch to restart it every block I go. This thing is going to be ten times more fun to cruise around on. I appreciate everybody's tips and things to check so much. I am going too put so many more miles on this thing since it is easier and more manageable on the road. Again, Thanks. |
04-13-2008, 06:54 AM
| | Re: New here. you are going to have a lot of fun and now you can help someone else who has the same kind of problems. Welcome to the world of motorbikes |
04-13-2008, 07:30 AM
| | Re: New here. The clutch can't determine the engines state of tune. Either you Chinese plug(s) were not very good, or you sealed an air leak when you RTV'ed the intake.
When you tighten the star nut, you essentially tighten the pressure on the clutch. This allows it to grab better, that's all.
Bottom line is you got it going.
Go ride.
04-13-2008, 08:25 AM
| | Re: New here. 55555555555555 thats a high five. time for you to enjoy your motorized bicycle. these things are a blast  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:17 AM. | | |
