FAQ
Members List
Calendar
Mark Forums Read
Pablo's Lubricants
ThatsDax.Com HOME OF THE TITAN XC 50CC 4 STROKE
Shifting Kits For Motorized Bicycles & More
80CC & 50CC
ENGINE KITS
ON SALE NOW!
Spookytoothcycles.com Bicycles, motors, and accesories
Motorized Bicycle Welcome Forum
Introduce Yourself
new builder in milwaukee has tech ???
User Name
Remember Me?
Password
Introduce Yourself
Welcome biker. We'd love to hear your story and let us know about your
motorized bicycle
projects!
Discussion at
Motorized Bicycle Engine Kit Forum in the Introduce Yourself
forum. hellow all. first time poster here. After a quick 5 hour build ( rough fit ) the bike fired right off the ...
LinkBack
permalink
08-21-2008, 05:49 PM
reason
Motorized Bicycle Apprentice
hellow all.
first time poster here. After a quick 5 hour build ( rough fit ) the bike fired right off the bat the very first try. Seems to run like a dream. No smoke even with the heavy break in mix. Replaced all hardware on motor except head bolts. That stuff really sucked. I rather have allen key bolts with locktight over the soft screw head stuff. I got a 27 tooth sprocket fron Kings. this is a great product. I did find machineing it to half the thickness at the disc brake mount point helped with chain alinment and frame clearance. The chain idler sucks and it will replaced soon with a spring loaded idler sprocket. I hope this will make quick and ez removal of rear wheel. I have already caused a pinch flat on the rear in the first 10 miles of rideing. Me and the bike together weight about 310 lb. This moveing at around 30 ish mph on a hard tail is a little much for bike tires. Im looking into options to fix this. Any sugestions would be great. I plan to move to a susspension seat post. Also a Mavic tire that will run over 100 psi. The other issues i am haveing is with the excess of stuff on the handel bar. I have a duel pull break handel on the way from olympic bike supply to help this a bit. I am still looking for a quality thumb throttel to get rid of the poor plastic twist throttel. If you know of one that does not cost an arm and a leg let me know.
Now for the one big problem i cant figure out. The engine under load is makeing a high pitch squeeling sound. I have tryed a few cluch ajustments that have not helped. To me it sounds like bearings or the clutch. It only showes up in the top 1/3 of of the rpm range. If the motor is reved out with the clutch in it sounds fine. I also suspected the chain line to be a possability, but after geting the chain angle with in 2 degrees of being completly straight i no longer thik this is it. If any one has ideas on this please let me know.
So far top speed is 38 mph. I will be back with dyno info soon. F.Y.I if you have a Iphone or Ipod touch you can get very good dyno info on your ride. I will also have data on watt output all the way from dead stop to top end.
once again hellow to every one. I am looking forward to any feedback or questions you may have
Reason
2
permalink
08-21-2008, 05:58 PM
reason
Re: new builder in milwaukee has tech ???
you can find pics of the bike on my facebook page.
Login | Facebook
Reason
3
permalink
08-21-2008, 09:08 PM
skyl4rk
Welcome from the other side of the lake
I think the squealing is gear noise and the solution is to add some type of lube to the gearbox. When I did it I just used wheel bearing grease on the gears but I hear that there are other better recipes of liquid plus grease (ATF fluid? Mystery Oil?) Sorry don't remember but do some searches to find out.
4
permalink
08-22-2008, 05:38 AM
reason
thanks for the info. I did add a small amount of U.S army issue nasty black grease. I did go very light applying it with a tooth brush. I was worried about fouling the clutch. Sounds like a lighter oil type product may do better. Have you ever heard of any one useing a wax style lube like " White lightning " with any luck? Would you know if it is wise to clean the clutch and gears with brake cleaner before I lube again? I just blew it out with the air hose to start with. It seemed to be very clean. None of the metal shave I have heard about in other posts. thanks again
Reason
5
permalink
08-22-2008, 07:43 AM
Bikeguy Joe
MODERATOR
I use wheel bearing grease.
6
permalink
08-22-2008, 02:23 PM
fairracing31
Welcome to the forum, glad you joined us
The Beggining
hand brakes on coaster brake bike
Show Printable Version
Email this Page
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
vB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
03:02 AM
Miner Skinz.com
Advertisers
Search Engine Optimization by
vBSEO
3.1.0
Contact Us
Archive
LinkBack
LinkBack URL
About LinkBacks
Bookmark & Share
Digg this Thread!
Add Thread to del.icio.us
Bookmark in Technorati
Furl this Thread!
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
