high idle
Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. my 80 cc chines bike idles high . has any one else had this problem? I've adj carb but no ...
Old 08-18-2008, 04:05 PM
Question high idle
my 80 cc chines bike idles high . has any one else had this problem? I've adj carb but no luck .
Old 08-18-2008, 04:35 PM
Norman's Avatar
LORD VADER Moderator
Default Re: high idle
Is your throttle cable adjusted a little bit too tight? there should be some free play in the twist grip before the throttle responds about 1/8" of free play is good.
norms-iron-works.tripod.com
Old 08-18-2008, 05:23 PM
Bikeguy Joe's Avatar
Check the carb to intake and intake to cylinder areas for leaks. Better yet, take them apart and seal them up with RTV on both sides.
Old 08-18-2008, 05:41 PM
I had the same issue with one of my bikes a while back & the remedy to it was exactly as Norman suggested, the cable did not have enough free play in it so every time I moved the handle bars left or right the engine statrted to rev higher & I couldnt get my revs down with the idle screw, gave the cable some slack & it fixed the problem instantly
Old 08-18-2008, 06:31 PM
Motoschwinn's Avatar
So you would adjust that at the top of the carb I would guess?
Well let me just quote the late-great Colonel Sanders, who said..."I'm too drunk to taste this chicken."
Kings 70cc 3200+ miles. Now on a Schwinn Point Beach.
Old 08-18-2008, 07:18 PM
misteright1_99's Avatar
I would just screw the cable adjuster IN a bit on top of the carb, or you could also adjust it at the throttle if it is not already screwed all the way in...
Old 08-20-2008, 06:22 AM
All hall Normam, thanks cable was adjusted too tight !! thanks again!!
