Hello from Québec, Canada
Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. Hi everyone ! I'm brand new in the motorized bicycle world and I'm just excited to install mine asap ! ...
Old 03-31-2008, 10:41 PM
Motorized Bicycle Apprentice
Default Hello from Québec, Canada
Hi everyone ! I'm brand new in the motorized bicycle world and I'm just excited to install mine asap ! But watch my case, it is some challenge for those who like to use their mind !
I own a Felt MP cruiser (see the link for pix : CustomBrigade) that I want to convert in a moped style but I face some difficulties:
- first of all I have a 7 internal speeds Nexus Shimano rear hub with coaster brake and the left flange is too wide for sprocket hole. I don't think that I can just lean it against the flange because of the chain line. And the sprocket teeth may certainly touch the left chain stay of the frame. Maybe I could drill or file the hole to enlarge it but I have to think of the fixing bolts that will be too close to the enlargement, and I don't even know if my bolts will pass throw the spokes (32, gauge 14, crossed 3, 50mm wide rims, just heavy duty my friend ).
- Then my tubing is pretty beefy so for fixing the engine, I'll have to review all the fixing gear. I dislike the idea of drilling my down tube frame so I'll try to find some way to built a customed attach or fixing gear.
- and the tank is designed for an ovoide tubing shape (round). Mine is a tank styled frame. (see pix). The bolts that are welded in the bottom of the tank are designed again to accomodate a certain tubin diameter. Mine is oversized and prevent me to lean the tank against the frame. Here again, I'll have to find a way to fix firmly and safely the tank on the bike (with some metal plates, straps and foam, I don't know yet)...
I'll take some more detailed pictures and measurments next post to be more precise.
So I told you it's no vacation ! And if I want to ride asap (the sooner the better), I need your wisdom. And don't tell me to change my bike.
I know it would be simplier to buy a good old 200 $ cruiser Schwinn at Canadian Tire, but I like to have some challenge, so if anyone as solved those problems, any comments and advice will be welcome. The worst for the moment is the sprocket. Should I check for a motorcycle or moped rear sprocket ? I know that I have to check the thickness of the sprocket, to fit a 415 chain.
Some other questions: I read that the spark and the wire is no sh.. in the chinese kit. Were could I find some good ones ? What kind of spark : I read in another post, it takes a cold one ? which #? And the wire, a 7 mm copper ? Where do I buy this ? Canadian Tire for example, or a motorcycle shop ? What's the best ?
I hope to capture your interest, thank you for your attention, hope my request isn't to long, and above all, excuse my english, I'm not used to speak and write a lot in english, but I'm motivated by my passion.
Thomas
Ps : the emoticons don’t work ?!
Old 04-01-2008, 02:25 AM
RedB66's Avatar
Default Re: Hello from Québec, Canada
Welcome to the Forum....Sounds like you have a challenge ahead of you!! There are several ways to mount these motors and tanks. From using U bolts around the frame to speacialized adapters. As for the spark plugs...upgrading is a good idea, Cruiser will be able to help you out on that one.
Old 04-01-2008, 05:19 AM
welcome you can use a round file on the sprocket to make it fit your hub. takes a bit of time. but its simple.
good luck I will keep an eye out for those pictures.
Old 04-01-2008, 05:48 AM
deacon's Avatar
Welcome my suggestion is to take it one challenge at a time. To enlarge the center hole of the sprocket, I used a metal rasp that fits my 3/8 inch hand drill. I think I paid about six bucks for it. I just drew a circle about an 1/8 in wide around the opening then ground out the metal to the edge. It wasn't pretty but I did it in less than half hour.
the only way to know about the bolts that go through your spokes is to try it, once you get the sprocket hole big enough to fit. Just fit one first then try the one directly opposite it. leave them loose till you get them all though the sprockets then tighten them. It might spread your spokes a little but it shouldn't do any real damage.
Also if anyone tells you to dump you bike tell them where to go. It is a beautiful ride. Also I know the urge to ride right away but it takes a week or two to do the first install. Well it took me that long but I had some real issues. I seized my engine lol
Oh yeah I didn't do it myself but I saw a motor mounted using a muffler clamp and thought that would be the best for a large frame. A muffler clamp uses a U bolt but also a bracket that is u shaped on one side and flat on the other. Get one big enough and it should work beautifully.
Old 04-01-2008, 06:33 AM
Ilikeabikea's Avatar
Welcome to the forum. My advice would be like deacon. Just take it one problem at a time. You'll have it up and going before you know it.......................
http://bdconner.com
Old 04-01-2008, 07:06 AM
CRUISER's Avatar
ADMINISTRATOR
hi tom and welcome to the forum. part of the fun of these is modifiying things to make them work. if you run in to trouble let us know and we will be glad to help you. glad to have you with us
http://stockmarketcats.com/
Old 04-01-2008, 11:01 AM
Welcome to the forum! Don't worry about the challenges, that's why we're all here.
So many potholes, So little time
Old 04-01-2008, 11:13 AM
Thanks guys for all the encouragement ! And I'm conscious that I'll have to take one problem at a time, my impatience is more due to seeing the winter finish, that means I'll be able to ride !
  #9 (permalink)
Old 04-01-2008, 11:16 AM
CRUISER's Avatar
ADMINISTRATOR
i know right where you are coming from thier. this was one heck of a long winter
  #10 (permalink)
Old 04-01-2008, 12:31 PM
deacon's Avatar
and now it's monsoon in the south
Similar Threads
Hello from Ottawa Canada Mopedamauter79 Introduce Yourself 7 04-01-2008 06:40 PM
Anyone from Canada Mopedamauter79 Motorized Bicycle General Discussion 3 03-31-2008 10:44 PM
Greetings from Canada wayde Introduce Yourself 6 02-04-2008 09:52 PM
Hello from Thunder Bay, Ontario Canada ChrisHill Introduce Yourself 2 01-19-2008 03:36 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
