| Sponsors
| | | | Introduce Yourself Welcome biker. We'd love to hear your story and let us know about your motorized bicycle projects! | Greetings from North of Lake Tahoe, CA Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. Just finished my 49cc in my Mtn bike--started right away and had me laughing, it was such fun---
however ...  | |
07-23-2008, 06:11 PM
| | Motorized Bicycle Apprentice | | Join Date: Jul 2008
| | Greetings from North of Lake Tahoe, CA Just finished my 49cc in my Mtn bike--started right away and had me laughing, it was such fun---
however now I want to start tuning, and my first problem is the carburetor--I idle way too fast and it wont adjust and it seems rich at speed
I'm at 5700 feet so I'm sure thats the problem, does anyone have any tips on what I can do to lean out this thing? thanks |
07-23-2008, 06:19 PM
| | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: memphis tn
| | Re: Greetings from North of Lake Tahoe, CA hey kenlani, welcome aboard
I'm sure one of the more experienced members will be along shortly to help you with your problem
good luck and happy motoring
Let the solution BE the revolution
07-23-2008, 06:55 PM
| | Re: Greetings from North of Lake Tahoe, CA Welcome to the forum, glad you joined us
Be sure you do not have any kink's in your throttle cable. Your cable might be too tight...adjust on the top of the carb...
To change the fuel mixture...move the clip on the carb.
Check post #5 the "e clip" Carburetor pictures how to install and rebuild
07-23-2008, 07:10 PM
| | Re: Greetings from North of Lake Tahoe, CA Sorry I forgot to mention to lean the carb move the clip up...to go richer you would move it down.  |
07-23-2008, 07:44 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: north bend wa.
| | Re: Greetings from North of Lake Tahoe, CA hi; it could be a vac leak at carb. mount. |
07-23-2008, 10:28 PM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Greetings from North of Lake Tahoe, CA welcome to the site. the idle screw is the only screw on the carb. i had to mess with mine alot to get it where i wanted it. also check both on the throttle and where joe put the picture of the cable coming into the carburator and make sure it is not kinded or to tight, glad to have you with us  |
07-24-2008, 10:18 AM
| | Re: Greetings from North of Lake Tahoe, CA Welcome to the forum. Lots of motorized bicycle enthusiasts here. Glad you joined us..........................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-24-2008, 06:46 PM
| | Re: Greetings from North of Lake Tahoe, CA I moved the clip up, runs a bit better, can adjust the idle faster, but I'm already idling way fast---my cables are not kinked and the adjusters at the throttle and on top of the carb are all the way in--so I have to be rich and need to jet for the altitude--
how do I get to "Classic Posts" to find where to buy some---anyone have an idea of what size down I should try? again I'm at 5700 feet----thanks |
07-24-2008, 09:03 PM
| | Re: Greetings from North of Lake Tahoe, CA I'd check for a vacuum leak first...use some wd-40, carb clean, brake clean, and spray around the manifold & carb. If the engine changes RPM you know you have leak and use some RTV to seal it up.
__________________ |
07-25-2008, 08:28 AM
| | Re: Greetings from North of Lake Tahoe, CA If you are too rich it won't cause it to idle high. You may be too rich because of altitude, but have an air leak so you are idling high.
What does your plug look like?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:16 AM. | | |
