| | | Introduce Yourself Welcome biker. We'd love to hear your story and let us know about your motorized bicycle projects! | Engine wont start Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. Hi, I just finished building my motor bike, and I only got it to start once. Now, i everytime i ...  | |
03-07-2009, 12:53 PM
| | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: New York
| | Engine wont start Hi, I just finished building my motor bike, and I only got it to start once. Now, i everytime i try to start it, it starts for a few seconds, then dies, then a lot of fuel just leaks out of the carb and exhaust. What should I do? |
03-07-2009, 01:46 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: Engine wont start Are you forgetting to turn the choke off? If not, it could be as simple as a stuck float in the carb. |
03-07-2009, 06:57 PM
| | Re: Engine wont start Did you do the stuff I told you about on the chat?
Is it still giving you problems?
03-07-2009, 09:29 PM
| | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: Winnipeg
| | Re: Engine wont start Sounds like it could be that the float level is set to high.Adjust the tangs down a little till the problem resolves it self. Don't forget to clean your plug! |
03-08-2009, 01:22 AM
| | Re: Engine wont start Quote:
Originally Posted by Bikeguy Joe Did you do the stuff I told you about on the chat?
Is it still giving you problems? | I opened the carb, looked inside, and had no clue what to do. (As in i took of the float bowl) |
03-08-2009, 01:23 AM
| | Re: Engine wont start How do I fix a stuck float in the carb?? |
03-08-2009, 05:18 AM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Las Vegas NV USA
| | Re: Engine wont start bend the brass tabs so that the float does not rise as high it looks like a brass y it holds the float |
03-08-2009, 02:13 PM
| | Re: Engine wont start Welcome to the forum, glad you joined us.
Bend the tab circled in red to adjust the float level, Down for less fuel, up for more fuel. Make very small adjustments. You may have to do it several times before you get it right. Carb Pics pictures by FR31MB - Photobucket |
03-09-2009, 12:10 AM
| | Re: Engine wont start Any luck yet? Have also come across pin holes in the float...that will weigh down the float allowing to much fuel to flow in. The floats are made of a very thin plastic and are virtually impossible to fix as they seem to always have the leak on the inside seam were the float floats up and down were the needle and seat are and the tolerances are to close to put any sort of patching compound as it restricts the movement of the float causing the problem to compound itself even worse...remedy-get a new float and replace. You will be able to tell if this is the problem by taking the float out and visually look to see if there is fuel inside the float itself.Hope this might shine some more light on the problem that you are having.
Regards,
gofast  |
03-09-2009, 07:26 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: Engine wont start Hi Roni, welcome. Sorry to hear your new build is not up and running yet but looks like folks are taking good care of you and all will be vroom soon. Please keep us updated with your progress.
__________________ Quote:
Originally Posted by NEAT TIMES looking In The Sky, May See Dan Flying By!! Ha Ha Ron | I want 2 ride my bicycle | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:34 AM. | | | Sponsors
