Disc brake modification
Discussion at Motorized Bicycle Engine Kit Forum in the Introduce Yourself forum. I'm brand new here. I just bought a motor and want to learn what I can before I mount ...
Old 05-15-2008, 09:49 AM
Motorized Bicycle Apprentice
Default Disc brake modification
I'm brand new here. I just bought a motor and want to learn what I can before I mount it. I have been a commuter for some time but just became intrigued by the motorized concept. I'm by no means a mechanic so I have lots of questions. I haven't seen anything yet about disc brakes but my first question is should I try to install a different brake system on my bike's rear wheel so I can install the sprocket, or should I install the motor on a different bike?
Buzzler
Old 05-15-2008, 09:58 AM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Disc brake modification
does you bicycle have rear disk brakes? most change to a different brake if that is the case. or you could take of the brake mount then put sprocket on to the spokes then replace the disk brake mount. or you can get a sprocket that mounts to the disk brake mount. lots of different options. welcome to the site and glad to have you with us.
Old 05-15-2008, 10:20 AM
nogoodnic's Avatar
Welcome to the forum Buzzler. What bike are you planning to use? We really like pictures here, show us what you've got...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 05-15-2008, 10:38 AM
Ilikeabikea's Avatar
Welcome to the forum Buzzler. Lots of motored bike enthusiasts here...................
http://bdconner.com
Old 05-15-2008, 05:59 PM
Thanks to all who replied. I have a Trek 4300 mountain bike. I'll try to get some pics for you. I do have a disc brake on the back wheel. The bike doesn't appear to have any "eyelets" to which I could mount a different type of brake system. I do like the discs and would pursue mounting the sprocket with the disc if you think that is doable. My concern was that I wouldn't have enough clearance between the disc brake and the sprocket. The instructions with my motor didn't address disc brakes at all. Where should I go to find parts for such an application? Thanks for the help.
Buzzler
Old 05-15-2008, 06:33 PM
CRUISER's Avatar
ADMINISTRATOR
kings sprockets under sponsers are all pre drilled with the six hole pattern for the disk mount.
Old 05-17-2008, 10:24 AM
cityevader's Avatar
I was dying to use my disc-compatible hub's unused mounting points for sprocket mounts, but alas, the sprocket would have hit the frame badly.
Perhaps there is room if you enlarge the sprocket center hole enough to clear the rotor's mounting jugs, bolt up the sprocket to the spokes, then remount the rotor to see if it all clears?
Old 05-21-2008, 10:48 AM
I would love to hear how running this setup goes if you elect to run disc rear brakes. I think mounting the motor drive to the spokes, on a properly dished wheel, and then mounting your rotor normally, would seem to be a clean solution and ought to work well. I am an MTB nut myself and would love to see one of these kits built up on a real quality MTB frame. With great braking I think I would take my motorbike many strange and exciting places indeed..
  #9 (permalink)
Old 05-22-2008, 03:45 PM
cityevader's Avatar
I think current 9 speed and older 8 speed cassettes might have too much dish (as was my problem with sprocket hitting frame) Way old seven speeds or singles I imagine would be best.
Years ago, when I was hardcore into mtn biking (20,000miles/year) I had dreams of having a detachable engine I could stash in some bushes at the bottom of tahoe, drive up, ride down Mr. Toad's Wild Ride or the Flume trail, then hook up the engine and motor back to the car. (This was after my riding buddies either moved, married, and/or had kids and stopped riding. Five years of solo riding sucked. I haven't ridden in six)
So yeah, a mountain bike with a throttle rocks!
Similar Threads
Installed my dual brake lever Pablo Motorized Bicycle General Discussion 9 05-16-2008 01:14 PM
chain tensioner modification Norman Motorized Bicycle General Discussion 11 05-06-2008 04:59 PM
Coaster brake danger! VENICE BOY Motorized Bicycle General Discussion 19 04-28-2008 06:38 AM
least expensive bicycle engine modification for performance CRUISER High Performance Bicycle Engine Tips 33 02-26-2008 10:20 AM
Front Drum Brake Autocycler Motorized Bicycle General Discussion 7 02-22-2008 08:54 AM
