Hello. I have the Chinese 80cc (the motor says 65.9cc, but the seller swears they just say that because of some EPA regulations and it's really 80cc's. but somewhere else i read... THERE IS NO 80cc BIKE ENGINE! he told me to check the forums, sp what do you guys think?) but anyway... I'm Very new to this and i wanted to thank all of you for being here and for helping me without even knowing you have, yet. :-P
i haven't even mounted my engine and i i alreayd looked inside my intake manifold to find that horrible blockage from where the two diff pices of that pipe are casted together. thank you SOOOO much for the heads up! I'm sure i've freed up at least twice the flow! I very tediously scored around that seem until it was mostly smooth. it took a long time working with what i had, but i LOVE the outcome! and i owe it all to you guys! never would have even thought about it! ^_^.
here's a laugh for you... i used the none sharpenned sides of a pair of titanium coated scissors, lol. it has a curved edge, so as not to score, too bad, and works alot better than you'd think, since it's so hard against just aluminum and makes 2 pretty hard 90° edges) and then finished off be running a steel wool pad through it and around it. so basically, DIY ported and polished! ^_^ i could have worked on the polished portion of it longer, but i was tired of messing with it, lol!
if anyone wants pic of my scissor ported (smoothed out and widened the openings) and steel wool polished intake.
i've also already got the NGK plug (modded to be shorter to clear my frame. PM me if you're interested in how that turns out) and a brand new plug wire, terminal, and plug wire elbow style boot.
ok, so to cut to the chase... I'm a speed demon. But i'm also doing this for mpg and i want it to last me! keeping that in mind... i'm VERY interested in some sort of exhaust upgrade. but i don't want to sacrifice the longevity of my engine, or much fuel consumption. so would this mod do this... or is it more or less, free power, like exhaust upgrades on a car... more power without sacrifice of mpg (except maybe for the cases where maybe low end torque, if you have a very low restrictive [low backpressure] set-up).
Also... if i did this, i would want somehting like kinda like this...
new exhaust WOW!!!
or like this one custom one i saw on a schwinn stingray. it was low and long, and gradually got wider, like a real motorcycle.
Any suggestions? what about any other worth while performance mods that won't sacrifice fuel economy too much? and i'll bet a pocket bike NOS setup would probably REALLY shorten the engine life, wouldn't it?
