| Sponsors
| | | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | what tends to break on the HT engine? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. do the cylinders just wear out, when you beat on them? or do they break rods?
I definatly hear more ...  | |
09-13-2008, 08:56 PM
| | Master Motorized Bicycle Builder | | Join Date: Sep 2008 Location: black mountain NC
| | what tends to break on the HT engine? do the cylinders just wear out, when you beat on them? or do they break rods?
I definatly hear more piston noise from mine durring warm up but not so much when its hot
I was thinking of putting an iron sleeve in one if the bottom ends are pretty bulletproof
Ive spunn the crap out of mine & it seems to be hanging tough but the rod & wristpin seem pretty wimpy
thanks for your input
take care
JAK |
09-13-2008, 09:05 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Independence MO
| | Re: what tends to break on the HT engine? Quote:
Originally Posted by jak stoll do the cylinders just wear out, when you beat on them? or do they break rods?
take care
JAK | The only thing that has broke on my 'vintage' kings motor was the cast intake. He sent me another 3 weeks after emailing him about it. In the meantime I got a chrome one from Dennis Foster. I'm now over 3200 miles, and it's still going strong. Wish I had bought 3 or 4 of his kits 4 years ago!
__________________ _________________________________________________ It's a mathematical fact, 10 out of 8 people have trouble with fractions. Kings 70cc 3200+ miles. Now on a Schwinn Point Beach. (And say HI to my Dad, he works there in the Archives!) |
09-13-2008, 09:31 PM
| | Re: what tends to break on the HT engine? thanks for the input :-)
I like my HT too
I have another bottom end coming that I plan to ballance (winging it) my only problem with the engine is the lack of balance
more what I was getting at was when you rev them really high what tends to break?
take care
JAK |
09-14-2008, 11:22 PM
| | Motorized Bicycle Apprentice | | Join Date: Sep 2008
| | Re: what tends to break on the HT engine? Owner's patience from stuff vibrating loose. |
09-15-2008, 03:01 AM
|  | Master Motorized Bicycle Builder | | Join Date: Jul 2008 Location: OC, Ca
Originally Posted by rcjunkie Owner's patience from stuff vibrating loose. | yeah. Patience wears thin after a couple of times of going over every bolt. But it's worth the hassle just so you don't go over the bars. Checking the bikes bolts also help.
There is no moment like the now moment.
09-15-2008, 09:44 AM
| | Re: what tends to break on the HT engine? Loctite and USA made nuts, bolts, and studs are the way to go. I also use locknuts even on the hot stuff and double nut whenever possible. |
09-15-2008, 08:17 PM
| | Re: what tends to break on the HT engine? Loctite blue and red are your friends (after warranty periods). I have a bike right now that has over 500 miles and nothing has fallen off.
09-15-2008, 08:20 PM
| | Re: what tends to break on the HT engine? I've seen some scuffed cylinder (more than likely due to cold seizure) and wrist pins that were very worn. One grenaded needle bearing engine, and beyond that, any prudent operation will more than likely need only rings, maybe a new cylinder/ring/piston set.
They aren't racing engines, or anything even remotely associated with one.
10-17-2008, 04:39 AM
|  | Motorized Bicycle Builder | | Join Date: Aug 2008
| | Re: what tends to break on the HT engine? how are you going to balance it ? there is only one cylinder these motors are counter wieghted to keep your reciprocating assembly wound up and give it enough velocity to push the piston back to the top of the cylinder when on your compression stroke. i have lightened the piston and pin considerably results = less vibration quicker revs. please post ideas on how your balancing it. |
10-21-2008, 01:38 PM
| | Motorized Bicycle Apprentice | | Join Date: Jan 2008 Location: I'm from Washington D.C. but now live in Martinsburg West Virginia
| | Re: what tends to break on the HT engine? Hi , I too had a Kings 70 and all was well with it for many a mile until the chain broke and jambed in the front sprocket housing and broke the engine case. It was the strongest running of any of the 5 H Time engines I've had over the last 4 years. The one with the most miles on it is the Dax 65cc that has bushings . I do run it with alot of oil in the mix but it has over 2 k miles on it and still runs as strong as ever.I have learned over the years the the HT quality is poor and the engines are not to be expected to do any more than a putt putt putt around town . Not for performance in any stretch of the imagination. I'm looking for a quality engine that I can abuse and that can take it or be built up to take it. It's come to the point now with my bikes that I tend to go slow and putt around cause I'm tired of braking the things and or going sailing over the bars. Tom in WV | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:18 AM. | | |
