| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | What spark plug do u use? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Just wondering what spark plug everyone is using, before I go out and buy every model in the NGK series.
06-12-2009, 12:57 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: NEWCASTLE
| | What spark plug do u use? Just wondering what spark plug everyone is using, before I go out and buy every model in the NGK series.
I use the BP6HS, I found this much better than the B6HS as the electrode protrudes futher into the head.
I was thinking of going for a cooler plug like a BP8HS.
Steve |
06-12-2009, 07:28 AM
| | Re: What spark plug do u use? B5Hs is what I have.
06-12-2009, 02:07 PM
| | Re: What spark plug do u use? I agree with Joe... Try the 5 first! |
06-12-2009, 02:45 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: What spark plug do u use? I use the B6HS gapped at .035
06-12-2009, 07:20 PM
| | Re: What spark plug do u use? I found no diff between the 5 & 6 so I went the cooler 6.
I recommend using the BP*** plug though as it seemed to give me much better results than the no protruding elctrode type b*** |
06-12-2009, 07:32 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: OC, Ca
| | Re: What spark plug do u use? Quote:
Originally Posted by cyclepro101 I found no diff between the 5 & 6 so I went the cooler 6.
I recommend using the BP*** plug though as it seemed to give me much better results than the no protruding elctrode type b*** | Just be cautios. You could protrude the plug too far.
There is no moment like the now moment.
06-12-2009, 10:30 PM
| | Re: What spark plug do u use? AutoLite 425 here |
06-13-2009, 12:29 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: What spark plug do u use? I have used champion cj7y when clearance was an issue
(it has a much shorter head) |
06-13-2009, 06:09 PM
| | Re: What spark plug do u use? I use a b7hs, talked to another guy using a b9hs. If you can get away with a colder plug your motor will have more power. You can buy a b7hs at shucks/checker for 2 dollars. Try one. If nothing else you b5 users will have a spare to toss in your bag. GL
__________________ Put something FUN between your legs.. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:49 AM. | | | Sponsors
