I found the adjusment on the throttle cable sux....i had the carb cap all the way out, the adjusters at the grip all the way out and the 90* coming off the throttle out. I couldnt get the throttle tight where the slack was gone. If ive got some slack then the throttle isnt opening as far as it could/should.
Heres what i did to give me more adjustment in the throttle cable...
I pulled the cable from the plunger in the carb, pull the plunger, carb hat, and spring off. Then i took a regular female wire connector and removed the guts from the center. I fed the throttle cable through it and put everything back together like normal. The connector needs to be pushed hard into the adjuster on top of the carb hat. Now I have lots of adjustment and just enough play in the throttle to drop the engine back to idle. Pics show what I did....works good. The connector fits tightly inside the carb hat's adjuster so it stays put...
