| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Walbro carb...which one? Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. I've read numerous references to Walbro carbs being used. I've tried googling them to see what bolt spacing ...  |
05-31-2008, 01:28 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Santa Cruiz, CA
| | Walbro carb...which one? I've read numerous references to Walbro carbs being used. I've tried googling them to see what bolt spacing they have, but no luck. There's quite a few to pick from, but no listed bolt pattern (my 70cc has approx 40mm spaced manifold bolts).
Anybody have a model number to help me out with? |
05-31-2008, 02:29 PM
| | Re: Walbro carb...which one? I do recall someone mentioning the model number on this web site....don't remember who or where.
05-31-2008, 07:40 PM
| | Re: Walbro carb...which one? I searched like crazy for you could not find part number. Easy Rider seems to be the one who use's it alot, you could try to PM him |
05-31-2008, 08:30 PM
| | Re: Walbro carb...which one? Ahh, I think I might have found it; part number HDA63
Post #43 page 5 Spy Pics of Team BoXer's full suspension race bike!
I would still PM Easy Rider to find more info, I think I read somewhere that some mod's have to be done for it to fit. |
06-01-2008, 01:12 AM
| | Re: Walbro carb...which one? Quote:
Originally Posted by fairracing31 I searched like crazy for you could not find part number. Easy Rider seems to be the one who use's it alot, you could try to PM him | I feel your pain...I do!
Searching like crazy has gotten me very disappointed!
Even stopping into a few small engine shops got me down, as they can apparently only look up parts on a "by-model" basis. Like such and such log splitter or trencher or weed whacker needs such and such carb... no dimensions or specs or bolt spacing.
SSSIIIIIIIIIIGGHHHHHH!!!!!!!!
I think I'll PM Easy Rider tomorrow. |
09-05-2008, 05:49 PM
| | Motorized Bicycle Newbie | | Join Date: Aug 2008 Location: seattle area
| | Re: Walbro carb...which one? I'm not sure about coming up one that's "bolt-on" ,but, I'm using a walbro carb that I got from pocketbikesunlimited.com and it works great. I did have to drill the manifold provided out to fit the "stock" intake manifolds diameter and drill/tap one hole through the "stock" intake manifold to match a hole in the carborators manifold. It was pretty easy and it works grrreat.
It was called a 16.5MM remote purge carborator, was for any of the 2-stroke 48cc pocket bikes and I just chose the 48cc model, though all of them are for 48cc engines the intake manifolds differ a bit bike to bike.
good luck... |
09-05-2008, 07:20 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Walbro carb...which one? Heres one that is a clamp on......... High Performance Dellorto carb found!
I run a mikuni, and it is also a clamp on...... 18mm Mikuni Upgrade |
09-23-2008, 06:51 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Lancaster, PA / Newark, DE
| | Re: Walbro carb...which one? I just ordered a Walbro HDA-63 (which is what Pipelyne told me they are using with their reed valve kit) from Russo Power Equipment - Walbro Carbs Carburetors (Walbro Carbs) for $53.50 +shipping if any one is looking for a source... |
10-02-2008, 12:40 PM
| | Re: Walbro carb...which one? stats about the HDA carb including mounting hole distance: Walbro | OrderTree.com (US) |
10-14-2009, 10:35 PM
| | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: santa cruz
| | Re: Walbro carb...which one? I JUST FOUND THE EXACT SAME CARB ON EBAY FOR 34 BUCKS. thought id let you all know cause i think its the best deal ive ever seen. with shipping its 39, and the seller is 100% positive customer feedback. look up walbro hda 63 carburetor on ebay | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:45 PM. | | | Sponsors
