Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
things Ive done with great results
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. hey there folks :-) Im jak stoll Jak Stoll Performance Im running the 70cc HT on a schwinn frame with worksman ...
Old 09-06-2008, 11:07 PM
Default things Ive done with great results
Im running the 70cc HT on a schwinn frame with worksman wheels Ill try to get pics up of it
I have a big 14 inch cut off wheel which I used the side of to shave off about .8mm or more from the head,
pulled out the lower jug gasket & used RTV
I was able to port out the inside of an extra stock carb I bought so the opening is like a stack inside of the filter & maybe got one mm or more in diameter
I went down with the floor & get a decent idle with the idle screw not touching the slide, air moves under, the mods on the carb leaned it out quite a bit so I got more RPM & when I dropped the needle back down got more torque
I think the compression made the biggest difference in pulling hills as well as top speed I also worked on the intake a bit
Im going to try the skirt tomarrow :-)
I love my old bike
I used to downhill in the late 70s before there were mountain bikes so this is like downhilling all the time with the 36 tooth rear sprocket I can get up to the high 30s low 40s on flat with neutral wind & have been clocked at 40MPH not wound all the way out :-)
I use a car fog light & a small truck marker in the back running A123 batteries to power them & just recharge them
anyway it will be nice to learn & contribute here, I plan on using a worksman frame & isolate the engine with rubber mounts in the future too
take care
JAK
here are a couple of pics...
things-ive-done-great-results-071908_2025-00-.jpg  things-ive-done-great-results-071908_2024-00-.jpg
Old 09-07-2008, 12:00 AM
fairracing31's Avatar
Default Re: things Ive done with great results
Welcome Jak to the forum, glad you joined us
Old 09-07-2008, 07:41 AM
Ilikeabikea's Avatar
Welcome to the forum. Looks like you been busy improving your motorized bicycle. We're glad you joined us.....................
http://www.galtx.org/
http://bdconner.com
Old 09-07-2008, 06:22 PM
hmmm :-) that would be 0B people :-)
I do tune in binary :-)
I tought myself believe it or not :-)
I use a graphing hex editor I have to correct checksums & all that :-) '
I dont know allot about 2 strokes but the fueling & moving more air is universal
I look forward to learning here
I love my bike & have put a fair few miles on it & have probably saved several hundred dollars or more on fuel
thanks for the warm welcome
on the carb I got it dialed in beter today, lowering the top of the jet holder to the floor of the venturi willlean it so I was able to then dial it in with the pin & it is way better
porting the carb is a viable solution if done well
take care
JAK
Old 09-07-2008, 08:11 PM
justbill's Avatar
when I had to learn hex to get my A+ certification, I thought my eyes were going to bleed
Bill (aka azbill, aka azkronic)
yesterday is history,
tomorrow is a mystery,
but today is a gift...
that's why it's called "the PRESENT"
Old 09-07-2008, 09:34 PM
nice group of folks here :-)
take care
JAK
Old 09-07-2008, 10:27 PM
Pablo's Avatar
What kind of exhaust are you using? You seem very knowledgeable and plain able - wait until you discover a tuned expansion chamber!
:welcome:
Old 09-08-2008, 09:21 AM
yeah Im getting to that
I messed around with the muffler that came with the kit & then ended up buying a better muffler but I do want to do an expansion chamber too
have a great day
JAK
PS nice bikes
  #9 (permalink)
Old 09-08-2008, 01:06 PM
hey Pablo
those shifter kits are pretty awesome :-)
worksman sells 3 & 7 speed internal hubs on their wheels I believe
Ill bet that took some effort to get rite
great value man :-)
take care
JAK
  #10 (permalink)
Old 09-09-2008, 07:35 PM
hey there guys :-)
I lowered the intake port floor a bit with my engine & WOW'
its got a real power band
I did loose a bit way way low in the RPMs but what I gained in the mid range is well worth it
I would strongly advise this method
someone here sugjested it & or modding the piston to change mechanical timing
it is a great move
I cant wait to get a expansion chamber on there
take care
JAK
Advertisers
