Re: Tanaka pipe problems. Jemma- If you change the length of the pipe ahead of the chamber, you'll change the RPM that it comes on the pipe. Shortening makes it (manifold) makes it get up on the pipe at a higher RPM. For optimal power, you'll need to find the RPM at which your engine makes the best torque and then set the pipe to come on there, for highest speed, find your peak horsepower RPM and set the pipe to come on there. Either way you will experience a large gain over a small range of RPM. You will more than likely have to play with the jetting a little so you don't burn your engine up, you will have to go richer for sure!
Also, could you just drill a couple of small holes and use some self tapping sheet metal screws or rivets to hold it all together? Three set at 120 degrees apart should be strongest.
