Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Stirling engine generator/hub motor idea
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Given we run IC engines on the bikes we are all wasting one large energy resouce... aka the heat from ...
Old 07-10-2008, 12:38 PM
Jemma Hawtrey's Avatar
Default Stirling engine generator/hub motor idea
Given we run IC engines on the bikes we are all wasting one large energy resouce... aka the heat from the exhaust.
These engines when running produce a hot exhaust which is just basically transmitted to air in the fumes and by radiant heat.
How about fitting up the muffler of an engine with a stirling heat engine running a small 12v generator (a bottle wheel dynamo for example). The power from this could be used to trickle charge a battery on the bike all the time the engine is running and/or used to provide lighting.
The battery could then be utilised to power a hub motor for short bursts, such as hill-climbing or fast running for short periods...
The advantage of this idea is that there is no drag on the drivetrain so it doesnt slow the bike.
just a thought..
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
Old 07-10-2008, 05:57 PM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Stirling engine generator/hub motor idea
Good idea!
Stirling Engines, Waste heat recovery, Sterling Engines- American Stirling Company Home Page
Stirling engine - Wikipedia, the free encyclopedia
Old 07-10-2008, 06:08 PM
hi jemma; i enjoy your way of looking at the possibilities of these little engines. as soon as i can i will try nitro idea, the sterling is beyond me. again you go girl. mitch
Old 07-16-2008, 12:36 PM
Jemma, Always thinking outside of the box that is so cool. I never get these cool ideas my brain is always confused with other Crap lately.
Old 07-16-2008, 01:56 PM
Umm... I have plenty of 'crap' to distract me at the moment... being almost to the point of eviction and a terminally ill girlfriend being the two major issues at the moment.
But its true, I do have a unusual mind that seems to go off at tangents... another being using a stirling engine generator to help power offices, using the waste heat from all the servers & computers in said offices
Jemma xx
Old 07-16-2008, 03:20 PM
deacon's Avatar
The only think I see that would cause me to wonder is the extra weight of the components not the generator but the battery it charges. It might be good to run a lighting system while the bike was moving but I wouldn't try to store the excess. The weight of the storage would probably cancel out any good from the generator.
Lights and horn now there's the ticket.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 07-16-2008, 03:27 PM
but if you are running a hybred the battery is already there.
Old 07-16-2008, 03:39 PM
deacon's Avatar
I have run ebikes they call hybred but they have no heat source. I have never run a gas and electric bike. I would think they would be terribly heavy and hard to manage though.
  #9 (permalink)
Old 07-16-2008, 04:29 PM
what i meant by hybred is an e-bike with gas motor like augies idea. i would think that to be an ideal situation or close to it. mitch
  #10 (permalink)
Old 09-05-2008, 05:24 PM
Motorized Bicycle Apprentice
Maybe if you wrapped a length of the exhaust with a coil that heated vegetable oil and fed into a small resevoir you could use this heated oil as the expansion side of the engine and use some fins on the air cooled vacuum side.
Then the stirling engine could keep running even when you are done riding and could then charge the batteries over a longer period of time.
Running the stirling engine on a shimano hubs an idea I've kicked around awhile. But I've only worked with beer can engines myself and have yet to make that much power, but I've seen engines that could and would probably benifit from one.
These engines get pretty big and make little power to size, but , it really aint that necessary to make huge watts when these batteries will only absorb so many watts per hour anyways. Maybe a smaller output but long lasting and "FREE" generator would be good? interesting.
Cool idea... last one I thought I'd see here but you made it apply. Rock on.
Advertisers
