Originally Posted by Nate D Here is a pic, bear with the resolution just snapped em with my Helio ocean 2mp.
Also a comparison next to the stock plug non-modified. |
OK I am back from a test run using the one I hear people buying the NGK BP6HS and the custom modded stock plug. Here are my findings. Feel free to try the 2 yourself and add your thoughts or feed back.
The NGK plug has a thicker core with a higher energy requirement so I found at low idle the spark wants to fade out due to the low electrical power produced during lower revolutions. You can kick the idle up however in an attempt to remedy this. This plug also extends slightly more which does 2 things, displaces space and increases compression. I found this slightly increased compression seemed a little more powerful on the low band (torque). Hear is the con, since the plug displaces more it lowers the actual displacement of the cylinder reducing the over all CC's of the motor. It was definately lacking power at the high end or top speed.
The Modded plug can idle better at lower rpm, still has significant torque and power increase at lower end of power band and also feels more powerful at the higher rpms.
Here are my thoughts. If you are going to be doing a lot of hill climbing or rough terrain and will not be going faster than 20 use the NGK and up your idle.
If you want good all around performance and plan to hit 30 every now and then, street and light trail riding then use the modded V tip stock plug.
I like to ride on the street, occasional hills, and hit the dirt bike trails now and again so the modded plug felt better for my needs. Yours might be different. As always, consider advice but make your own conclusions and try things for yourself. If you happen to try the free mod or come up with your own new design to try please share with the rest of us. Happy modding.
