Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Shorter intake tube = higher rpm
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Hi I know our china girls are not high rev/output engines But Asuming that the intake tube length has ...
Old 09-20-2008, 01:10 AM
velardejose's Avatar
Default Shorter intake tube = higher rpm
Hi
But
Asuming that the intake tube length has some role in carb vibration, and asuming that this vibration causes bubbles in the carb bowl and somehow limits the rpm
Shortening the intake tube would allow more revs?
Or would a 3rd mounting point be a better idea?
I would like to know your opinions
Thanks in advance
Old 09-20-2008, 02:04 AM
Egor's Avatar
Default Re: Shorter intake tube = higher rpm
The RPM limit is due to the design of the engine, there are some engines out there that have no intake runner and the engine would run better, just because of the restriction it causes, but I think there would not much increase in RPM. A 3rd mounting point is a good idea, most motorcycles use 3 and 4. I saw one bike with a turnbuckle from the top of the engine to the upper frame and he could adjust the tension. I would like to make one that would pick up the top head bolts and a nice bracket to go up to the frame. These engines use the torque and not the higher RPM"s. I change the ports and get the most out of the engine and then gear it up. I have a 39 tooth sprocket and it will still climb amazing hills and go over 35mph. Have fun, Dave
Chuck - The monkey has the spark plug again!
Advertisers
