Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Reed valve on the cheap
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. hey pitchfork do you know the part number for the echo reed valve?...
  #61 (permalink)
Old 10-28-2009, 10:13 AM
Default Re: Reed valve on the cheap
  #62 (permalink)
Old 10-28-2009, 09:35 PM
Anyone used the pocketbike reed assembly ? $6 thats on the cheap in my book.
  #63 (permalink)
Old 10-29-2009, 11:24 AM
I'm with you John. I would like to know how the echo reed valve worked too.
  #64 (permalink)
Old 10-29-2009, 07:18 PM
homemade reed valve cheap
here's a link to pitchforks reed valve setup
  #65 (permalink)
Old 10-30-2009, 03:31 AM
Got my PB reed assembly in today looks like theyll work.... aluminum bar stock on the way ...think its gonna be sweet
  #66 (permalink)
Old 10-30-2009, 04:02 AM
Originally Posted by scott83 View Post
Here is a good link I found several years ago on etching youre own reeds for use in pulsejet engines....the process is really simple...it aint rocket science ...but close..LOL.
www.aardvark.co.nz/pjet/makevalves1.pdf
And the page its from with good info on the design/theory of the assembly.
Factors Affecting Pulsejet Valve Life
it rocket surgury!!!
but anyway...how were the results...did this blow the crank seals out???sounds like a great idea if those crank seals can handle it and the motor can handle the higher compression...
  #67 (permalink)
Old 10-30-2009, 09:31 AM
I didnt do the etching process for this ....I spent like 10$ on a pocket bike reed assembly. Haven't had a chance to do any R&D yet .... still waiting on aluminum barstock... to make a decent "cheap" reed block adapter.
  #68 (permalink)
Old 10-31-2009, 01:12 PM
Didnt think about blowing crank seals...must be why Hodaka had you do this mod when installing reeds on thier bike www.strictlyhodaka.com/images/reed0006.jpg looks like it would prevent over pressure in the crankcase since intake and transfer would be equalizing until the piston moved past both of them. www.strictlyhodaka.com/images/reed0004.jpg Thanks for the insight think ill be doing this cylinder mod before I install my reed assembly.
  #69 (permalink)
Old 11-01-2009, 01:47 AM
that would definately reduse some of the crankcase overpressuring that i was concerned with...good research...but is this nessassary???how has other peoples been holding up???
oh by the way nice reed valves...how big are they????
  #70 (permalink)
Old 11-01-2009, 09:39 AM
Dont know...thats what I was wondering Ive not heard anyones stories on here I did see a thread somewhere on here that showed Pipelyne (I think thats how its spelled) had made some reed cages assemblies....but nothing on how well they work and they were like $100....... too rich for my blood....Im thinking $20 to $30 here and there is reasonable.....if its a hundred here and a hundred there I'll buy a Different Motor.
It would be good to know if the the cylinder mod is even required. Ill probably try without doing it and see... and if the seals go replace them when I do the cylinder mod.
