Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
Proto--type clutch pucks
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. That's good to know from our stand point. What motor do you have? I'm sure Pipelyne has a ...
  #11 (permalink)
Old 03-23-2008, 12:29 PM
Easy Rider's Avatar
Default Re: Proto--type clutch pucks
That's good to know from our stand point. What motor do you have? I'm sure Pipelyne has a die that can stamp out one of those square pads.
  #12 (permalink)
Old 03-23-2008, 12:42 PM
It's a "Kings 80cc" and i am so happy with it. i will be keeping an eye on this thread, that's for sure. Thanks! That pic was from kings site as well.
  #13 (permalink)
Old 03-23-2008, 06:15 PM
Norman's Avatar
LORD VADER Moderator
Yea thats the first time I saw round pucks. those look just like my airplanes disc brakes pucks. Those about the size of a quater? My brakes are gurdies same as on the coorslight silver bullet airplane/BD-5J. They are only slightly better than dragging my feet but I don't want to be able to lock them up and stand the plane on its nose either make the prop real short. Your pucks got me to wondering.
norms-iron-works.tripod.com
  #14 (permalink)
Old 03-23-2008, 10:03 PM
Easy Rider's Avatar
I know if I put both feet on the ground and engage the clutch slowly until fully engaged, It doesn't slip at all. Our new clutches grab pretty good and will probably last the life of the motor.
  #15 (permalink)
Old 03-24-2008, 05:43 AM
Motorized Bicycle Apprentice
I think a wet clutch setup would require a lot of maintenance because we don't have any pump or a filter to catch clutch material. The oil would quickly become a grinding paste then attack the gear train unless it was changed very often. I'll stick with a dry setup and moly grease.
  #16 (permalink)
Old 03-24-2008, 04:24 PM
Bikeguy Joe's Avatar
A good wet clutch like a bike has would be nice- you'd be able to slip it a lot and only change the oil on occasion.
  #17 (permalink)
Old 03-24-2008, 04:53 PM
I 'm sure it would quieten things down as well. All that oil would deaden the sound and I've always thought that that was where most of the racket comes from. After re-thinking my thoughts though, I realize that the "pucks" would soak up the oil and the bike would not move. The clutch plates on a real bike are not made from a sponge-like material.
I would encourage easyrider to think about this though. He would have nothing at all to lose, he just needs to come up with a better material. If things don't work out it's just a matter of cleaning things up and replacing his pucks.
Similar Threads
Moutain bike - clutch/brake lever?? Pablo Mounting Techniques 20 06-29-2008 07:28 PM
bicycle engine clutch. Norman Bicycle Engine Kits 43 05-29-2008 02:06 PM
How do i mod this type of pipe baffle?. Markpee High Performance Bicycle Engine Tips 5 05-28-2008 03:17 PM
clutch lever ran49 Bicycle Engine Kits 4 03-12-2008 06:33 PM
motor bicycle clutch Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 7 02-11-2008 07:04 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
