| | | High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. | Port intake on bicycle engine Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. That is what I am saying. It is restricting. All you have to do is your exaust and intake manifold. ...  | |
05-12-2008, 01:24 AM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Daytona Beach
| | Re: Port intake That is what I am saying. It is restricting. All you have to do is your exaust and intake manifold. I could have cut so much off that it would have broke in half, but stoped when I felt structural integrity may be a problem. Do not even have to monkey around with the head. Shoot if you just grinded off the crummy weld stuff you would have done something. Ya, I need to get around to my exuast. Did you notice any difference? |
05-12-2008, 07:50 AM
| | Motorized Bicycle Newbie | | Join Date: Apr 2008 Location: newcastle .Australia
| | Re: Port intake i too have matched all the ports etc,made a big difference. but i do run a tuned pipe and chamber aswell |
05-12-2008, 11:05 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Port intake Yes it seems to run smoother thru the powerband. I want to try running it without boost bottle next, I pinched it off and made quite a difference. |
05-13-2008, 10:08 PM
| | Re: Port intake Bike, ported the exaust today, when I took the muffler off I noticed a chunk of weld right there where the exaust exits the very end. Probably restricting 5 to 10% where it finaly exits, my dremmel wheel was a perfect fit. I was so excited that I almost tried to ride it without my High temp Copper RTV being dry have to wait 24 hours. I do not know if the RTV I used is so great, the packeage says do not use on gasoline areas, I think the stuff on my intake is starting to shoot out the sides. |
05-13-2008, 11:09 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Albuquerque
| | Re: Port intake Hey guys made It a 150 miles no leak on head. I was wrong on underestimating this china eng. considering better studs longer with jam nuts. any input? also have come to the conclusion its better to keep these motors at proper tork spec soes not to distort the cylinder walls. You guys are dead on about your check up ref! on everything so far. |
05-14-2008, 12:37 AM
| | Re: Port intake What about stud thing again. What happen. Take back what I said about orange RTV, probably will work. |
05-14-2008, 07:13 AM
| | Re: Port intake M6X1.00 threaded rod for the studs. Use a small amount of high strength loctite on 'em and DON'T over tighten them. Double nuts are a good idea. http://motorbicycling.com/f30/bicycl...-care-354.html
06-04-2008, 06:19 PM
|  | Motorized Bicycle Newbie | | Join Date: May 2008 Location: S.F. East Bay
| | Re: Port intake on bicycle engine Where can you find metric threaded rod? My hardware store carries a wide variety of metric nuts and bolts, but not all threaded rod.
Andy- |
06-04-2008, 06:32 PM
| | Re: Port intake on bicycle engine I have seen posts referencing a co. called McMaster? For threaded metric rod. |
06-04-2008, 06:52 PM
| | Re: Port intake on bicycle engine Ahhh, how could I forget McMaster-Carr
I love that 300mm cost more then 1m.
Overall Length Each
30 mm 98833A250 $7.48
40 mm 98833A255 7.76
50 mm 98833A260 8.03
300 mm 98861A525 22.42
1 m 98861A320 13.36
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:33 AM. | | | Sponsors
