Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
Port intake on bicycle engine
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. That is what I am saying. It is restricting. All you have to do is your exaust and intake manifold. ...
  #11 (permalink)
Old 05-12-2008, 12:24 AM
Default Re: Port intake
That is what I am saying. It is restricting. All you have to do is your exaust and intake manifold. I could have cut so much off that it would have broke in half, but stoped when I felt structural integrity may be a problem. Do not even have to monkey around with the head. Shoot if you just grinded off the crummy weld stuff you would have done something. Ya, I need to get around to my exuast. Did you notice any difference?
  #12 (permalink)
Old 05-12-2008, 06:50 AM
Motorized Bicycle Apprentice
i too have matched all the ports etc,made a big difference. but i do run a tuned pipe and chamber aswell
  #13 (permalink)
Old 05-12-2008, 10:05 AM
misteright1_99's Avatar
Yes it seems to run smoother thru the powerband. I want to try running it without boost bottle next, I pinched it off and made quite a difference.
  #14 (permalink)
Old 05-13-2008, 09:08 PM
Bike, ported the exaust today, when I took the muffler off I noticed a chunk of weld right there where the exaust exits the very end. Probably restricting 5 to 10% where it finaly exits, my dremmel wheel was a perfect fit. I was so excited that I almost tried to ride it without my High temp Copper RTV being dry have to wait 24 hours. I do not know if the RTV I used is so great, the packeage says do not use on gasoline areas, I think the stuff on my intake is starting to shoot out the sides.
  #15 (permalink)
Old 05-13-2008, 10:09 PM
Hey guys made It a 150 miles no leak on head. I was wrong on underestimating this china eng. considering better studs longer with jam nuts. any input? also have come to the conclusion its better to keep these motors at proper tork spec soes not to distort the cylinder walls. You guys are dead on about your check up ref! on everything so far.
  #16 (permalink)
Old 05-13-2008, 11:37 PM
What about stud thing again. What happen. Take back what I said about orange RTV, probably will work.
  #17 (permalink)
Old 05-14-2008, 06:13 AM
Bikeguy Joe's Avatar
M6X1.00 threaded rod for the studs. Use a small amount of high strength loctite on 'em and DON'T over tighten them. Double nuts are a good idea.
Bicycle Motor Preperation And Care
  #18 (permalink)
Old 06-04-2008, 05:19 PM
Andy's Avatar
Default Re: Port intake on bicycle engine
Where can you find metric threaded rod? My hardware store carries a wide variety of metric nuts and bolts, but not all threaded rod.
Andy-
  #19 (permalink)
Old 06-04-2008, 05:32 PM
I have seen posts referencing a co. called McMaster? For threaded metric rod.
  #20 (permalink)
Old 06-04-2008, 05:52 PM
Andy's Avatar
Ahhh, how could I forget McMaster-Carr
I love that 300mm cost more then 1m.
Overall Length Each
30 mm 98833A250 $7.48
40 mm 98833A255 7.76
50 mm 98833A260 8.03
300 mm 98861A525 22.42
1 m 98861A320 13.36
Similar Threads
70cc bicycle engine vs. 50cc bicycle engine RedB66 Pre-Motorized Bicycle Information. 9 05-27-2008 08:48 AM
looking for engine for bicycle.. NEW here. steve's bike Bicycle Engine Kits 12 04-30-2008 10:12 AM
thatdax.com large intake manifold? Pablo High Performance Bicycle Engine Tips 7 04-28-2008 12:42 AM
Re: bicycle engine gusjdj Introduce Yourself 4 03-15-2008 03:47 PM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
