Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
PipeLyne pipe
Discussion at Motorized Bicycle Engine Kit Forum in the High Performance Bicycle Engine Tips forum. Well I got my new pipe....Verrry good work,Nice pipe...Installed in minutes...I think I have just about worn out my motor ...
Old 12-19-2008, 03:23 PM
Default PipeLyne pipe
Well I got my new pipe....Verrry good work,Nice pipe...Installed in minutes...I think I have just about worn out my motor trying to tune it now.....I thought it would need to be richer so I kept dealing with trying to go richer.....Plug kept getting darker,so I put on a STOCK carb. I had.....It ran on top very good but middle needed work....Got that , now it won`t idle worth a crap....When I ride it and coming to a stop and pull the clutch in, it seems to not want to come down to idle, revs are sky high...I though it was gonna blow for a min. till I hit the kill button.....Whats up with that, cable not bound or kinked....No air leak, o-ring in carb.....Still way lean on the ??????
Thanks,
Paul.....
Life in the Fast Lane......
If your living on the edge , you`re taking up too much space....
Old 12-19-2008, 04:46 PM
Easy Rider's Avatar
Santa Cruz Scooter Works
Default Re: PipeLyne pipe
That sounds like a carb, linkage or air leak problem. Sometimes even though the cable is not kinked, the cable could fall out of the cable adjuster. Try wiring the throttle cable and attach it to the cable adjuster on the carb. This will prevent the cable from pulling out & getting caught up on the cable adjuster. Also check near your throttle. If all else fails, use a stronger throttle spring.
Link to the Pipelyne tuned pipes
http://motorbicycling.com/f23/new-sc...-sale-189.html
Old 12-19-2008, 05:04 PM
Thanks, thats my next place to look at......I`ve had the top off the carb. so many times changing needle height it might have got a kink in it.....
Thankyou,
P....
Old 12-20-2008, 11:34 AM
Figured out why she was n`t coming back to idle and over revving.....Big time air leak at the carb. manifold where carb. connects to it....I put a regular hose clamp on it and cured the prob......Even though I put an o ring in the carb. it still leaked vac.
Old 12-20-2008, 11:51 AM
SO what performance gain are you getting from the pipe?
Old 12-21-2008, 10:50 AM
AFTER getting it jetted and tuned right, it runs alot better.....Smoother transition between off idle to top speed....I`m actually out running my rear sprocket now....I need a smaller one,I have a 40 toother coming....Just a little louder than the stock one thats modified....Has that dirt bike cackle now.....More torque on the bottom to mid....
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
